OpenSSL: error:0906D066:PEM routines:PEM_read_bio:bad end line (RT-AC87U_380.69_2.trx)
Max.M
I am using a RT-AC87U with RT-AC87U_380.69_2.trx and tried setting up hide.me connection with their files, for example „Frankfurt.ovpn“.
After loading the file, I only changed the settings:
TLS Renegotiation Time: 1800
Connection Retry: 60
Username and password are not relevant for the reproduction of the problem (entering something will do).
When I start the connection “Error - SSL/TLS issue!” appears besides the ON switch, and the log says:
Feb 16 18:50:49 openvpn[1527]: OpenSSL: error:0906D066: PEM routines: PEM_read_bio:bad end line
Feb 16 18:50:49 openvpn[1527]: Cannot load CA certificate file ca.crt (no entries were read)
Feb 16 18:50:49 openvpn[1527]: Exiting due to fatal error
[note that I put a space between : and PEM to avoid : P :P smile]
If I install the previous version RT-AC87U_380.69_0.trx and factory-reset the router the exact same configuration works (at least by manually turning the connection on; version 380.69_0 shows some problem on “Start with WAN”: The connection establishes and the log looks fine – but either the routing or the “Policy rules (strict)” / “Block routed clients if tunnel goes down“ does not update allowing traffic flow).
[note that I put a space between : and PEM to avoid : P :p smile]
RT-AC87U_384.4_alpha1-gc4fc92d.trx fixes the OpenSSL: error:0906D066: PEM routines: PEM_read_bio:bad end line issue; I'm still trying to get “Start with WAN” VPN connections routing all internet traffic.
Thank you!
RT-AC87U_384.4_alpha1-gc4fc92d.trx fixes the OpenSSL: error:0906D066: PEM routines: PEM_read_bio:bad end line issue.
This version appears to be also MUCH faster than RT-AC87U_380.69_2.trx
-> Just sent a 25 USD donation and a big THANK YOU for keeping up the development of this great software!
Also, “Start with WAN” works fine. I found that the issue was related to my additional VPN Connections"Policy rules" :
VPN Connections in "Service state: OFF" should be set to "Redirect Internet traffic: ALL"
(Manually setting "Service state: OFF" does not switch off the "Policy rules" of a VPN Client - so a client in "OFF" state can still block traffic from being sent through another client).
