OpenVPN Client: Advanced settings
hw1380
Router: RT-AC68
Firmware: 380.58
I'm not sure what are the best settings in the advanced settings sections of the openvpn client.
Currently these are my settings:
Accept DNS Configuration: disabled
-> Then the DNS servers are being used which I have set in WAN tab.
-> setting it to "Exclusive", then a private 10.X IP-address from my VPN provider is being used.
# In both cases, I have no DNS leak but what is recommended ?
Verify server certificate: yes
What is recommended, yes or no ?
Redirect Internet traffic: All traffic
What is recommended, "All traffic" or "No" and what are the implications ?
Router: RT-AC68
Firmware: 380.58
Use: Exclusive, then you don't have any DNS leaks from vpnprovider.
No
Depends if you want all clients or some being redicted.
No
I have heard that this could allow man-in-the-middle attacks ?
OK.
Setting this to "no", there is no option to select the clients which will not be redirected.
That's the reason why I was thinking of using the "Policy based" option.
I'd like to have only one client to use ISP and all others through VPN tunnel.
But I got it not to work. I have added the following policy:
Source IP 192.168.1.5 Destination IP 0.0.0.0 lface WAN
After that all clients are using ISP and not only this particular IP.
This essential because Amazon Instant Video is using geo-blocking like Netflix and I'm not able to play videos on my Smart-TV while connected to VPN.
Set "Redirect Internet Traffic" to All traffic.
and client exeptions to: Source IP 192.168.1.5 Destination IP 0.0.0.0 lface WAN
then only that ip goes to WAN
If I choose redirect internet traffic to all traffic, I have no option for client exceptions.
I managed to exclude the IP by adding the following rules by choosing policy based:
Source IP 192.168.1.0/24 Destination IP 0.0.0.0 lface VPN
Although I have set "Accept DNS configuration" to Exclusive, I have a DNS leak all of the sudden.
But this time I have tested on ipleak.net
My IP and my WebRTC IP shows the IP of the VPN but both DNS-Servers are the IPs which I set in WAN tab.
Are you sure your VPN-provider push dns-address?
When you test with ipleak.net its through vpn-tunnel?
Do set any other dns servers ?
Se if you have any dns: cat /etc/openvpn/dns/client1.resolv
In /etc/openvpn/dns/client1.resolv: 10.10.55.1
Then you should see that and your vpn-address on ipleak.net
hmm 10.10.55.1 is lan net address, are you on double nat?
No, I guess this is the NAT address from my VPN provider.
During checking the changelog of the later releases than mine, I found a fix:
380.59 (10-May-2016)
- FIXED: OpenVPN clients set to policy-based routing and Exclusive
            DNS mode were still adding the tunnel nameservers to
            dnsmasq, causing both routed and non-routed clients to use
            them.
Since 380.62 is still in beta, I will wait until the final version is being released.
Does anybody know if I can just update from .58 to .62 (with reset to factory defaults, of course) ?
            them.
Try to update to 380.59 or .61 and test. I'm sure 10.10.55.1 is local lan address.
Class Private Networks Subnet Mask Address Range
A     10.0.0.0     255.0.0.0     10.0.0.0 - 10.255.255.255
Now I know where this 10.X IP address comes from: since two days my ISP is providing NAT'ed 10.X addresses as a WAN address. His IPv4 address pool runs out of free addresses.
After this change I have trouble to resolve any hostname on the clients if I switch off the VPN.
If I switch on the VPN again, everything is fine.
