Has anyone able to achieve any decent download speeds with an OpenVPN Client configuration on an Asus router with either the latest Asus or Merlin FW? In particularly, connected to provider such as Hide My butt. The reason I include the latter is because I am suspicious the problems (5-8 Mbps dl on a 80Mbps line) I experienced are not related to the router setup nor the FW I used. I have used the same setup except the server was that of a friend and received near perfect results. Granted, this server was very near by, however, the results were 10 X better than what I achieved with the paid provider. Surely, 200 mile distance between my friends network and the paid provider cannot result in such drastic difference in performance.
My questions to you are:
Is it normal to see download speeds reduced to 10 % of normal speeds when setup as a OpenVPN client?
If not, what provider do you use? what is your router setup???
BTW1: Windows7 OpenVPN client setup with same provider produced identical dismal results.
BTW2: N66U L2TP setup with same provider produced near "perfect" results.(55-72 Mbps DL)
