openvpn client
bilboSNB
A while ago I had been using the openvpn client to access other countries google playstores but for some reason this no longer seems to work. :confused:
If I check myip etc,or go to speedtest.net all looks good and internet traffic is correctly routed.
Running a vpn direct on my tablet seems to work.
Any ideas, or can some one else try and see if they get the same behaviour?
Do not understand, your openvpn client connected to openvpn server? Check system log, ping server's side.
If yes, then check routing or use the "Redirect Internet traffic" in openvpn client settings.
Yes the vpn client on the router is connecting to vpn service and all internet traffic redirected.
However, not for play.google.com after cache delete etc, it still seems to know where it is being accessed from.
Been a while since I looked at this but traceroute seems fine:
vpn on then off:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Billy>tracert play.google.com
Tracing route to play.l.google.com [216.58.216.110]
over a maximum of 30 hops:
  1     2 ms    <1 ms    <1 ms  proxy.server [192.168.0.1]
  2   133 ms   136 ms   137 ms  10.10.0.1
  3   148 ms   131 ms   140 ms  hosted.by.leaseweb.com [198.7.62.253]
  4     *        *      140 ms  ae3.cr1.wdc1.leaseweb.net [108.59.15.120]
  5   138 ms   136 ms   132 ms  te5-4.msc2.wdc.leaseweb.net [217.20.125.36]
  6   455 ms   307 ms     *     217.20.125.89
  7     *        *        *     Request timed out.
  8   483 ms   306 ms   257 ms  64.233.174.41
  9   286 ms   306 ms   208 ms  209.85.248.125
 10   311 ms   305 ms   306 ms  216.239.46.154
 11   252 ms     *      256 ms  64.233.174.6
 12   519 ms   306 ms   214 ms  64.233.174.91
 13   414 ms   307 ms   305 ms  209.85.254.241
 14   292 ms   306 ms   307 ms  72.14.238.17
 15   293 ms   305 ms   306 ms  ord30s22-in-f14.1e100.net [216.58.216.110]
Trace complete.
  1     2 ms     2 ms     2 ms  proxy.server [192.168.0.1]
  2    22 ms   100 ms    20 ms  195.10.125.82
  3    19 ms    19 ms    18 ms  195.10.125.114
  4    19 ms    23 ms    20 ms  195.10.119.154
  5   150 ms    48 ms   265 ms  212.30.0.25
  6    49 ms    48 ms    48 ms  xe-10-0-0.edge5.Paris1.Level3.net [212.73.200.5]
  7    55 ms    54 ms    54 ms  ae-121-3507.edge4.London1.Level3.net [4.69.166.9
  8    56 ms    55 ms    54 ms  ae-121-3507.edge4.London1.Level3.net [4.69.166.9
  9    53 ms    52 ms    54 ms  72.14.203.126
 10    55 ms    67 ms    55 ms  209.85.255.76
 11    56 ms    55 ms    55 ms  216.239.51.7
 12   129 ms   127 ms   127 ms  216.239.50.224
 13   149 ms   142 ms   142 ms  209.85.246.37
 14   145 ms   142 ms   143 ms  216.239.50.237
 15   147 ms   145 ms   145 ms  72.14.238.17
 16   143 ms   141 ms   142 ms  ord30s22-in-f14.1e100.net [216.58.216.110]
Trace complete.
C:\Users\Billy>
Merci.
