OpenVPN issues with RT-AC88U: 382.1 Beta 1
alons
Hello experts.
After experiencing some issues with the latest stable version 380.68_4 on AC88U (resolving addresses became very slow and occasionally timed out, worked fine on _2, but that's for a different thread), I decided to give a try to the latest beta version on my AC88.
Everything is working ok so far, we are back with normal behaviour/speed, except for the OpenVPN server.
I noticed 2 issues: the EXPORT (client.opvn) file does not include the server certificate and keys (it has to be added manually by cut/paste), this was not the behaviour in the stable builds, and i wonder if it's a bug or a feature, either it's easy to work around this problem. 2nd issue is that i cannot authenticate to the server, it initiates connection, but times out on "connecting". After some trial/error i was able to connect by setting, user/passwork auth. only, which is of course not the desired mode of work, but do provide me with a temporary solution.
I wonder if anyone experienced similar issues.
thank you,
Alan.
It's a bug in the certificate validation code.
