Frankflash
Definitely a bit buggy, looks like speed shaping is working bidirectionally for LAN clients but on my wireless clients its only applying to downloads.
whats speed shaping and what does it do
cound use wireshark to see whats going onMakes no difference at all, beta 3 unstable and previous version 384.13 is stable
Is there anything I can capture when these disconnects occur to find out why?
I suggest you add the router to only access the WAN, try and see if that helps. Like this:
Description Source IP Destination IP Iface
router 192.168.1.1 0.0.0.0 WAN
lan 192.168.1.0/24 0.0.0.0 VPN
Not in my opinion. I get the same results.
DSLReports speed tests are very geographically dependent.
For anyone living in major Canadian cities, for example, their speed tests are horribly unreliable as they're not actually a test of YOUR internet connection ... it ends up becoming a test of your ISPs transit links + how much congestion is occurring at that particular day/time.
That's why I recommend FAST.COM instead. Nowadays, Netflix has put their caching appliance on almost every ISP's internal network across North America. So by using FAST.COM you can actually test your OWN internet connection and stuff like bufferbloat etc. - without introducing foreign variables, like your ISP's over-burdened peering connections, excessive transit congestion because it's 8:30pm on a weekday, etc.
Edit: Another decent one is TESTMY.NET. They're also more reliable than DSLReports speed tests.
I live in central Canada and I get strange results as well.Nope, FAST.COM no good for all of Europe - limited.
A little better than DSLReports, but finds me a server in Amsterdam, Holland - 2.000km!
P.S. Even gave me on second test 100Mbps more than my max connection - ridiculous!![]()
Don't use smart connect if you want stability, also disable beamforming and airtime fairness on 2.4 I'm referring to. Some say disable mumimo as well. Also pick a channel 1,6,11 thats it.Decided to take a dive with the RT-AX88U. Been having issues with random drops from mostly 2.4Ghz devices. Loaded up Merlin's latest beta 3 and will report back if there is any success.
Not sure if this is a bug or not. Came from the factory firmware over to Merlin and right off the bat it changed my wireless networks to open networks. Not a huge deal as setting them back to WPA2 and existing settings were there. Guest network was not affected.
I have seen a lot of iffyness with the "Smart Connect" feature. Does it work and is it usable? Would it just end up causing even more drops?
Thanks for the great work Merlin!
Rely more on the tcpdump tool.yup Fast.com is terrible in Canada.
ok will give that a try later on and report backthanks for the help.
Welcome To SNBForums
