Hello all -
I have multiple VPNs types going, Wireguard (via raspberry pi not via router), IPSec on RT-AX86U, and IPSec via Instant Guard -- the last two are really just me trying them out and as alternatives to Wireguard.
I am running stock firmware.
They all work well and as expected.
What I really want as an alternative is OpenVPN but on TCP 80 or TCP 443. Reason being that in very locked down networks those ports are almost sure to be open - whereas IPSec and UDP are completely blocked.
This is the warning in the GUI for OpenVPN on the RT-AX86U
It says it is a "suggestion" but what they really mean is if I type in a port <1024, it will not accept it. I don't know exactly what the security concern is other than that these are well known ports.
Does anyone know of a workaround to this restriction?
Thanks.
Thanks.
