Tuneboy2005
That's odd, are you trying to access them by Name or IP? If by name, you would probably need to enable the respond to DNS as well on the server side.
Ok appearantly a reboot of router was required. Think it is working. When i now connect over 4G to the VPN on router and check on "whatsmyip.org" i see the home WAN adress instead of the public adres i get from my mobile provider.
