Openvpn speeds, second core openvpn code on RT-AC87U ?
The way i understand it is that if you want to move your 100% of vpn utilization to on one core you would want to use odd number so 1, 3, 5 instead of even.
In case of 87u 5GHz (which is all i will use) runs on different (second) cpu on it's own so not sure what will run on 1st processor on core 0 when vpn will use core 1 with 1, 3, 5 client setup ?
This is sweet setup the way Merlin has implemented it as now speeds of vpn can be way higher comparing to previous routers. I got my router last night so my puppy is here already.
Maybe John or Merlin can chime in. I think i understand this correctly.
