OpenVPN TLS Renegotiation Time Storage
TonyK132
Does anyone know where the TLS Renegotiation Time value is stored, and if it generates a CRON job, where that setting is located? I had a problem with my VPN (I use PIA) that whenever the Regeneration Time occurred, it would interrupt my streaming audio. No browser that I tried (FF, Vivaldi, Brave, Chrome) could deal with the discontinuity in the VPN stream, so I increased the time to happen once/day, but I would like the Renegotiation Time to occur at 4am when I do not care about an interruption in the streaming audio. Alternately I could wake up at 4am, and cause a change to the VPN screen that would (presumably) cause that Time to reset to once/day at 4am. But I would like a procedure that is more definitive.
The renegotiation time is a duration not a time of day. Why not set it to zero if it's a problem? Alternatively, if you need the duration to start at a particular time you could create a cron job that restarts the client.
Yes, a duration. But I'm guessing it creates its own cron job, which is exactly what I'm looking for. But I like the idea of a duration of zero, which I guess means Never. What would be the commands that I would give it with my cron job, presumably to stop then restart it?
Another hint as to what's going on. I came to my PC at around 21:40, and saw that the streaming stopped. Don't know when it stopped, but I did find this this crash info in the logs. Does this mean anything to anyone?
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: Hardware name: Broadcom-v8A (DT)
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: task: ffffffc010cf4b40 ti: ffffffc0091dc000 task.ti: ffffffc0091dc000
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: PC is at 0xf71879cc
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: LR is at 0xf72c4ee0
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: pc : [<00000000f71879cc>] lr : [<00000000f72c4ee0>] pstate: 60070010
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: sp : 00000000ffbe95b8
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x12: 00000000f7306b38
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x11: 000000000002889c x10: 0000000000028458
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x9 : 00000000000175e9 x8 : 00000000000288a0
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x7 : 0000000000000018 x6 : 00000000f77046d0
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x5 : 0000000000000004 x4 : 0000000000000000
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x3 : 0000000000000010 x2 : 0000000000000001
Dec 22 18:57:45 RT-AC86U-1BD0 kernel: x1 : 0000000000000000 x0 : 0000000000000000
What OpenVPN command or commands can I use to cause a TLS Renegotiation to happen? I'm thinking I would put that into an executable script, and cron it to happen at 4am.
As Merlin said, it's handled internally by OpenVPN. So you'd need to restart the client connection.
killall -s SIGHUP vpnclient1
or
service restart_vpnclient1
or
Thanks, that's what I was looking for.
What's handled by OpenVPN is a duration until the next renegotiation. Doing a cron lets me set it to a specific time.
