Optimal settings ASUS RT-AC5300 with Merlin 386.3.2
L2TP by itself doesn't have any encryption. You basically only change your external IP to the one of the exit server. Your in/out data is visible and you can be blocked at any time on a simple firewall. My suggestion is to switch to encrypted OpenVPN. You'll have significant speed drop though, perhaps down to 70Mbps. This is what AC5300 can do. For more you need a newer ARMv8 CPU router with AES support. You may get to 200Mbps speeds. For even more - x86 hardware firewall or change of protocol to Wireguard.
Here, ExpressVPN example for L2TP on a router:
"Important: L2TP does not offer any encryption and should only be used for anonymization or for changing locations. If you are located in a country with a high level of internet censorship, you are recommended to use the ExpressVPN app for a more stable VPN connection."
What you can try is OpenVPN TCP on port 443. It's harder to block and may go through.
