Out of memory errors on rt-n16
133794m3r
as it says above I'm getting a memory error for some reason. I am using/running entware. and for some reason now the ram usage has literally exploded.
Before entware it was using barely 30MiB of ram now it's using 77MiB which makes no sense to me. What's up with this extremely high ram usages? Also is there anyway to make the /tmp director ythat things use to be on disk maybe? I was trying to run mitmproxy. And it kees saying noram. Before doing entware ram usage was barely above 30MiB.
Even with caches it's saying ~77MiB is being used. I've not installed any scripts or anything that'd be using it. And I've looked through it all and can't find it.
Anyway the router has a total of 128MiB which should beway more than enough for most everything. I'm debating on using a swap file on my usb drive to try to allivate this issue.
Also is there a way to change all of the tmpfs to zram or something similar to save some ramspace?
