Lefebvres090428
Hello all,
My current system runs 3 Rt68u routers. 1 is the main router and handles all the assigning of addresses etc and the other 2 are running in ap mode and are connected via Ethernet cable to the main router. Currently they broadcast different ssid (I tried the same but found it better if I was able to manually connect to the closest router if needed. Roaming did not always work and just found this works better) everything works great in the house. I now want to extend my signal to our pool house. This is open line of sight about 200-300 ft away depending on where I mount the antenna.
I would like some ideas on how to best get signal to the pool house? My thoughts are 1) to run an outdoor antenna from one of the antenna ports on the main router. (Longer cable run (60ft) from antenna to router but shorter distance antenna to pool house (200ft)
2) run an outdoor antenna from one of the antenna ports on an ap router. ( this would be a shorter cable run ( 20ft) from ap to antenna but a longer distance from antenna to pool house (300ft)
Is there any advantages/disadvantages to either option? How about antenna recommendations? Do I need a receiver antenna on pool house to aid in sending a signal back to the house from our devices? (Would purchasing 2 more 68u and running one in media bridge mode and then mounting the other next to it and running that one in ap mode with a Ethernet cable connected between them work to give a fast solid signal and would only be relying on devices to send signal to the ap that is really close and the media bridge would do the long range sending back to the outdoor antenna that is hooked to the router)
Would like to run a small tv and would do some light streaming, run phones and echo dot for music.
I have managed to get a decent working system in the house and really don’t want to mess too much with it and want the simplest way to just add outdoor coverage without running an Ethernet cable because there is really no good way to bury the cable since my drive way is in between.
Thank you in advance for some suggestions!
