outgoing traffic blocked asus rt-ac68u merlin
grantiago
Hi. Just setting up this router. All basic settings so far.
I have an ubuntu server on a static ip. All outbound traffic from the server is blocked. Am I missing a setting?
The only things I changed from the standard:
  • I have created a /jffs/configs/dnsmasq.conf.add
  • firewall is turned off.
  • I've set the DCHP ip pool
  • I have assigned several static IPs
from the server I can't ping anything.
from the router I can ping everything.
from the windows command line I can ping everything.
Make sure the gateway and DNS are correct on your server. Asuswrt does not block any outbound traffic.
Thanks. I have the lan>default gateway set to the routers ip. 192.168.1.xxx
the lan>dns servers are set to google 8.8.8.8 & 8.8.4.4
nothing.
I can switch back to my dd-wrt netgear wndr3700 and all works as expected.
factory reset and all well now. thanks. now I will start tweaking it one setting at a time and see what I did wrong.
A Suspicious Outgoing traffic on RT-AC86U ASUS AC Routers & Adapters (Wi-Fi 5) 52
