Just tried it, and unfortunately this happens:
admin@RT-AC66U:/tmp/home/root# nvram get clkfreq
600,300,150
admin@RT-AC66U:/tmp/home/root# openssl speed aes-128-cbc
Doing aes-128 cbc for 3s on 16 size blocks: 1890497 aes-128 cbc's in 2.98s
Doing aes-128 cbc for 3s on 64 size blocks: 505405 aes-128 cbc's in 2.98s
Doing aes-128 cbc for 3s on 256 size blocks: 129497 aes-128 cbc's in 3.00s
Doing aes-128 cbc for 3s on 1024 size blocks: 32341 aes-128 cbc's in 3.00s
Doing aes-128 cbc for 3s on 8192 size blocks: 4072 aes-128 cbc's in 3.00s
OpenSSL 1.0.0m 5 Jun 2014
built on: Fri Jun 6 16:34:33 EDT 2014
options:bn(64,32) rc4(ptr,char) des(idx,cisc,2,long) aes(partial) idea(int) blow fish(ptr)
compiler: mipsel-uclibc-gcc -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT - DDSO_DLFCN -DHAVE_DLFCN_H -ffunction-sections -fdata-sections -DL_ENDIAN -DTERMI O -O3 -DLINUX26 -DCONFIG_BCMWL5 -DDEBUG_NOISY -DDEBUG_RCTEST -pipe -DBCMWPA2 -fu nit-at-a-time -Wno-pointer-sign -mtune=mips32r2 -mips32r2 -DRTCONFIG_NVRAM_64K -DLINUX_KERNEL_VERSION=132630 -DOPENSSL_SMALL_FOOTPRINT -fomit-frame-pointer -Wa ll -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DAES_ASM
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes
aes-128 cbc 10150.32k 10854.34k 11050.41k 11039.06k 11119.27k
admin@RT-AC66U:/tmp/home/root# nvram set clkfreq=662,331,165
Doing aes-128 cbc for 3s on 16 size blocks: 1894520 aes-128 cbc's in 2.99s
Doing aes-128 cbc for 3s on 64 size blocks: 508465 aes-128 cbc's in 3.01s
Doing aes-128 cbc for 3s on 256 size blocks: 128925 aes-128 cbc's in 3.00s
Doing aes-128 cbc for 3s on 1024 size blocks: 32358 aes-128 cbc's in 3.00s
Doing aes-128 cbc for 3s on 8192 size blocks: 4070 aes-128 cbc's in 3.01s
options:bn(64,32) rc4(ptr,char) des(idx,cisc,2,long) aes(partial) idea(int) blowfish(ptr)
compiler: mipsel-uclibc-gcc -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -ffunction-sections -fdata-sections -DL_ENDIAN -DTERMIO -O3 -DLINUX26 -DCONFIG_BCMWL5 -DDEBUG_NOISY -DDEBUG_RCTEST -pipe -DBCMWPA2 -funit-at-a-time -Wno-pointer-sign -mtune=mips32r2 -mips32r2 -DRTCONFIG_NVRAM_64K -DLINUX_KERNEL_VERSION=132630 -DOPENSSL_SMALL_FOOTPRINT -fomit-frame-pointer -Wall -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DAES_ASM
aes-128 cbc 10137.90k 10811.22k 11001.60k 11044.86k 11076.89k
Performance is unchanged
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
And yes, I have bootloader (CFE) 1.0.1.4
