i have overclocked now my rt-ac68u with this tutorial by @kvic my question is what is the point if me, us, overclocked cpu to higher level?
sometimes i connect over OPENVPN from outside my local network for watching IPTV....so, should be get 5-10% more internet speed with 1200Mhz?
It's kind funny ,I did the same thing as you with my ac3200First of all the simple observation from the RT-N66U device:
After update of the firmware the overclocking need to be set once via nvram set clkfreq=662,331,165 and nvram commit - and it will survive the restart (hard and soft - see below).
Otherwise the default values of clkfreq=600,300,150 are used.
Now the more complex (and important) behavior on the RT-AC68U device after the update to the version 378.56_2:
I have set the desired overclocking in the init-start script via nvram set clkfreq=1200,666 and nvram commit to overcome the lock-down of the current Asus firmware.
After a hard reset (power toggle) the settings force the CPU to the overclocking performance:
And the nvram show | grep clk shows: clkfreq=1200,666 - same as the web interface (reading the same value).Code:chief@RT-AC68U:/tmp/home/root# cat /proc/cpuinfo Processor : ARMv7 Processor rev 0 (v7l) processor : 0 BogoMIPS : 2398.61 processor : 1 BogoMIPS : 2398.61
But after a soft reset (reboot button in web GUI for reboot command via telnet) the CPU performance is at default speed settings only:
But still the nvram show | grep clk shows: clkfreq=1200,666 - which is not the true speed!Code:chief@RT-AC68U:/tmp/home/root# cat /proc/cpuinfo Processor : ARMv7 Processor rev 0 (v7l) processor : 0 BogoMIPS : 1599.07 processor : 1 BogoMIPS : 1599.07
Conclusion: if you want your router to run faster, do not forget to set the init-start values and always do a power toggle in case you need to restart it!
Update:
Over night the NVRAM variable was reset to clkfreq=800,666 - looks like something is re-reading the CFE values and updating the NVRAM settings...
But the good news is that BogoMIPS : 2398.61 shows that it's still overclocked.
With kind regards
Joe![]()
I set the clock at 1400,800
and checked the bogomips before and after
but it didn't change ,it said 1998.06
but with a clock of 1400,800
Could it be false reading?
Yeah the clkfreq will show you false reading even when your Mibs the true speed is showing you
2398.61. If you dropped to
1599.07 you're at default 68u cpu speed. Without the script which was posted ealier in this thread after reboot you will get back to default Mibs.
Script will get you permanently 2398.61=1400mhz speed even with reboots.
I this is what I get for not reading the whole thread,sorry
I use the router for the torrents (not heavy ones) and file server.i have overclocked now my rt-ac68u with this tutorial by @kvic my question is what is the point if me, us, overclocked cpu to higher level?
Hi, what's the final code you ended up using?. Can you post it here please, thanks.Thanks joe but how do i intergrate this with this script. I don't want to randomly place anything as that is bad news usually.
mkdir -p /jffs/scripts
echo "#!/bin/sh" > /jffs/scripts/services-stop
echo "nvram set clkfreq=1400,800" >> /jffs/scripts/services-stop
echo "nvram commit" >> /jffs/scripts/services-stop
chmod 755 /jffs/scripts/services-stop
cat /jffs/scripts/services-stop
I've been meaning to overclock my AC68U ever since 378.56_2 came out, right now I'm on 380.58.
1. Enable scripts on your router. Make sure it's enabled. Very important.
2. Enable SSH in your router.
3. Log onto router using putty or other ssh client.
4. Copy and past each line and click enter after each line. This will put script in the directory.
5. Type reboot and click enter.
6. Check your temps few times that day to make sure it's not higher then 90C. Ideal temp 68-74C.
If over 90C you have warped heat sink and either need to get fan or get heat sink replaced/repaired or have dust ball inside your router.....lol
7. On .58 firmware and higher use only 1, 3 and 5 vpn client for optimized vpn speed code as listed in merlin change log.
8. If one has 87u using 5Ghz only (disabling 2.4Ghz) will give you 10-15% extra speed increase as 87u will use seperate 5ghz cpu processor for wifi. One should use 5Ghz anyway as it's least utilized bandwidth vs 2.4Ghz.
In case your router rejects the overclock you will have to do Asus recover using rescue 2000 from asus website. Max i've seen on 68u/87u is 1400. My 87u soft bricked at 1600. I've seen 1600 on 88u as i think it has higher stock clock speed. Usually those CPUs take 40% overclock over stock speed.
VPN speed increase of 200Mhz is marginal ~5Mbps so beyond that it's not worth it. All current asus overclocked ARM routers will do max 60Mbps on VPN 128 AES, 45Mbps 256 AES.
Thank you for the detailed steps. Do i need to add this code as well?
joegreat said: ↑
"Here we go:
# set clkfreq on each restart (due to change in CFE/NVRAM handling by ASUS)
#nvram set clkfreq=1000,800
nvram commit
Move the # to the line which need to be blocked..."
No don't use this and you're welcome. This is only temporary and will not work in few days. Use the script as this line does the same thing echo "nvram set clkfreq=1400,800" >> /jffs/scripts/services-stop
If you ever decide to go back to normal just format script directory using firmware and reset to default if you wish.
Also don't bother checking nvram clk speed as it will still how 1000Mhz. Use Mips code posted earlier cat ....something as that will show you Mips which is real speed. If you read entire thread i think it's all there as i was digging into it![]()
/proc/cpuinfo does not contain frequency. You can have a rough estimation of the frequency simply by dividing BogoMIPS value by 2. For example BogoMIPS : 1998.84 means that CPU runs at 1000MHz (1GHz).I tried but it didn't work, am i suppose to check yes on
"Format JFFS partition at next boot"
I access router via https://192.168.1.1:8443 it shouldn't really matter right?
Final Edit: Figured it out, I have to check clock frequency via using this
cat /proc/cpuinfo
I'm on a Rt-ac56u and previously the scripts were working. But recently I've checked the bogomips numbers and seems that nothing is sticking. Any ideas what changed? Is my jffs corrupted?Hello, where you finally able to overclock your rt-ac3200 ? I am not able to get the overclock to stick, even with the two scripts (init-start and services-stop) in place and after a reboot... if positive, what version of merlin are you using, what o/c speeds ?
Check if the script services-start is really executed by adding something like:But recently I've checked the bogomips numbers and seems that nothing is sticking. Any ideas what changed? Is my jffs corrupted?
Welcome To SNBForums
