Hi all,
A couple of months ago I posted about a problem in logging in to the router SMB server from the Oppo 103 player. I later found out that the 103 also support NFS so I setup NFS Exports on the AC86U and tested a couple of MKV files and they played fine.
I recently bought a 14TB WD external USB drive and ripped all my bluray disc in MKV container format. Anyway, depending on the movies bitrate, the video would stutter/pause randomly for a second or so, 10 or 20 times during the movie. Low bitrate movies seem to play fine, but high bitrate movies 30-40 mbps stutter a lot. The same movies stream fine from Windows via NFS and I have tested NFS transfer rate from Windows and it's more than high enough for bluray so I'm not sure if the problem is with the Oppo or something else. The Oppo ethernet port is only 100mbps, but that should be enough for 1080p bluray. I have tried both Merlin 384.19 as well as 386.1beta5 with the same exact problem.
I wanted to see if the AC68U had the same problem but NFS server would not start (also tried turning on/off support for V2).
System log show, "kernel : svc: failed to register lockdv1 RPC service (errno 97)". Tried resetting router to factory settings, but didn't change anything. Running firmware 386.19 but same problem with beta5 386.1.
Only difference between AC86U and AC68U is the former running in access point mode and the latter in router mode.
I then flashed the AC86U with ASUS firmware 384.32799 as all of the latest version no longer support Samba V1 and the movies stream smooth as silk via SMB.
Any idea why NFS fails to start on the AC68U with both Merlin latest firmware as I'm curious to know if it has the same problem. Also any suggestions on what to try on the AC86U?
Thank you
Thank you
