Per IP Traffic accounting
is it possible to disable hardware acceleration on AX88U ? (if yes, how ?)
You can do it in SSH, but it may not stick. Enable something incompatible with hardware acceleration - Traditional QoS, Cake QoS or Bandwidth Limiter. Hardware acceleration will stay disabled. Your router will turn into up to 350Mbps WAN-LAN router though, limited by the CPU.
ok. so you say , iptables can not collect correct information from accounting tables.
Try running the commands in this post:
oh thanks.
finally something useful :)
so to disable HW acceleration:
nvram set fc_disable_force=1
nvram set runner_disable_force=1
nvram commit
service reboot
and to enable back:
nvram unset fc_disable_force
nvram unset runner_disable_force
nvram commit
service reboot
this really works.
so does that only affect WAN-LAN access , or also LAN-LAN access ?
My uplink is only 100Mbps.
So if it only affects WAN-LAN as 350Mbps, then I'm OK with that.
But wouldn't want to limit LAN-LAN (wifi)
In theory must be affecting WAN-LAN traffic only, both ways. LAN-LAN is switched traffic, not routed. Not sure how WLAN-LAN is processed in HND routers. You can check this quickly on your router, faster than I can fire up one HND Asus router and verify.
how can I check it ?
in previous post I had asked a method to test speed between 2 Android devices or 2 PCs.
Something like that ?
my internet connection is DL 100Mbit/s , UL 10Mbit/s
so if the HW acceleration is just affecting LAN-WAN access, 350Mbit/s is enough for me both ways.
But is there any other consequences of disabling HW acceleration ? What is "HW acceleration" actually ?
Your WAN-LAN connection (Internet) won't be affected by NAT acceleration disabled. For LAN-LAN and WLAN-LAN traffic just copy a large movie file and watch the transfer speeds. LAN-LAN (wired to wired) must show up to 940Mbps speeds, or >100MB/sec. WLAN-LAN (wireless to wired) speed depends on the wireless client part. WLAN-WLAN (wireless to wireless) speed depends on wireless clients plus it will be up to 1/2 of the maximum possible speed to the slower client. The reason for 1/2 speed is because the same radio has to serve both clients in the same time.
I'm not sure I follow you. English is not my native language. Could you clarify it for me:
I want to be able to measure what bandwidth each client uses. So I want to disable HW acceleration with the suggested method above.
But I need to understand what I lose when I diable HW acceleration.
So, let me understand what is "HW acceleration" ? When I disable, does it disable some HW that normally router uses?
And what are the effects ?
I understand it limits LAN to WAN (and WAN to LAN) speed by 350Mbit/s , which is fine because I already don't have such bandwidth.
What about LAN-LAN and LAN-WLAN speed ?
When I disable HW acceleration, does it limit LAN-LAN & LAN-WLAN ?
No, there is a simple to understand explanation here.
As I said above, LAN-LAN is not routed, but switched traffic. It's unaffected by NAT acceleration. It's the Switch inside your router. Your All-In-One "router" consists of Router, Switch and Access Point components. LAN-WLAN shouldn't be affected as well, but I don't know how WLAN traffic is processed in your HND router. Higher CPU load in WAN-LAN may or may not indirectly affect WLAN performance. Some "routers" use more CPU for WLAN (like AC68U), some less (like AC86U). All-In-One routers do WAN-LAN-WLAN traffic in the same time. You can test and see if you have any WLAN performance differences with NAT acceleration ON/OFF in your normal use. I believe, it will be the same or very close on RT-AX88U.
ok. thanks for this explanation. I also read the explanation in the link (NAT acceleration)
so basically with my state (uplink at 100-110Mbits) , there is no importance of HW acceleration.
And since I want to follow bw usage of clients on LAN, I will disable it with following commands:
nvram commit
service reboot
these won't affect anything other than HW/NAT acceleration, is that correct ?
and since these won't survive a reboot/restart, I want to put these commands in a startup file.
Which file should I use for this purpose ?
is "/jffs/scripts/services-start" fine ?
Btw, I am really looking for a good way to test client to client max bandwidth test. File copying does not show anything more than 50Mbit/s
is there any good tool to test ?
btw, I just disabled HW acceleration ; first output:
- cpu temperature increased 0.5 C (from 76 to 76.5)
- wl1 temperature not changed
- wl2 temperature decreased 2 C (from 50 to 48)
- cpu idle % not changed
