Permanently moving traffic.db and syslog.log over to a USB Drive?
It seems that the parameters have changed
Possibly, (or you need to run dos2unix on the script) but use of scribe/syslog-ng is now the preferred method of moving Syslog to disk.
and/or I am not using the GNU versions of the logger and syslogd?
syslogd: invalid option -- 's'
BusyBox v1.31.1 () multi-call binary.
Just as a comparison, can you please check the version of syslogd?
syslogd --help
BusyBox v1.25.1 (2020-04-05 13:34:30 EDT) multi-call binary.
Usage: syslogd [OPTIONS]
System logging utility
(this version of syslogd ignores /etc/syslog.conf)
 -n  Run in foreground
 -R HOST[:PORT] Log to HOST:PORT (default PORT:514)
 -L  Log locally and via network (default is network only if -R)
 -O FILE  Log to FILE (default: /var/log/messages, stdout if -)
 -s SIZE  Max size (KB) before rotation (default:200KB, 0=off)
 -b N  N rotated logs to keep (default:1, max=99, 0=purge)
 -l N  Log only messages more urgent than prio N (1-8)
 -S  Smaller output
 -H NAME  Use NAME as hostname
which syslogd
/sbin/syslogd
Many thanks.. I am seeing:
# syslogd --help
        -S              Smaller output
        -t              Strip client-generated timestamps
# which syslogd
/opt/sbin/syslogd
I installed the syslog-ng and the same version came from it..!
Oh I see -- there are two syslog's on my system..
There is one at /sbin/syslogd as well..
and that one has the options you mentioned..
so shall I rename/delete the /opt/sbin version?
# syslogd --help
        -S              Smaller output
# which syslogd
/opt/sbin/syslogd
If you wish to continue with the script, then you need to amend the script to explicitly call the non-Entware version '/sbin/syslogd'
@Martineau
Thanks for this script, I use it long-standing but, at the moment, it needs an update :D
In the new firmware (384.19) the date and time log at startup has changed and the script is not working well.
I was able to manually change the date to line 144 of syslog-move.sh to identify the correct one but in MyCustomAction.txt and BOOT_errors.txt files I also find other messages that have nothing to do with it.
Additionally, a syslog.log-1 file is also kept in both the /jffs and /tmp folder and this file is added in the router's web interface system registry.
Is it possible to correct these errors without rewriting the entire script?
Thank you
@Martineau
Thank you
A lot has changed in the three and a half years since I first wrote the script!!!o_O
Yes the script can certainly be be tweaked, but most now use Entware utility syslog-ng to manage/move Syslog to USB. see here
e.g. either create custom syslog-ng filters to create the 'MyCustomAction.txt' and 'BOOT_errors.txt' files or simply clone/improve the scripts original 'grep' commands
grep -iE "ERR|FAIL|ABORT|INVALID|IGNOR|WARNING|out of memory" $SCANTHIS >> $ERRORFILE
to run a few minutes after the boot process has quiesced (either with a sleep delay in init-start or schedule a cron job) to scan the appropriate syslog-ng files.
