I am running it and it works great except that for some reason my devices are mostly using ipv6 to hit the pi hole so the client list is messyJust wondering if anyone is running a pihole on a raspberry pi and with Unbound on there router?
Thinking of doing it as I have couple raspberry pi 4 around
Thanks for the update on the 64 bit. Just have been running twister OSRunning a Pi 3B+ with Pi-Hole + Stubby DoT for add blocking. Also running Zoneminder on the same Pi for a couple of IP cams. Save my Pi 4 8GB for fun projects.
BTW there is a 64 bit version of Raspberry OS that works well. Still in beta but I do not have issues with it.
You can run unbound on your Pi too. I've been doing that config with my Pi's for quite some time. No issues. Pi-hole and PiVPN along side. Set up Pi-hole on both and run 2 DNS services.Just wondering if anyone is running a pihole on a raspberry pi and with Unbound on there router?
TwisterOS, while really flexible, is still 32 bit. The 64 bit can be turned on but the rest of the apps/programs will still be 32 bit.Thanks for the update on the 64 bit. Just have been running twister OS
While 64bit is nice, it can also be reasouce hog with some programs. If the rpi is mainly only for pihole and or unbound I would not see a need for it to run as a 64 bit. Simple 32 bit would suffice.TwisterOS, while really flexible, is still 32 bit. The 64 bit can be turned on but the rest of the apps/programs will still be 32 bit.
Run the lite version of Raspberry OS 64 or Ubuntu server 64 bit on a Pi-4
here is mineI'm running this configuration on a Pi and it works well. I have all devices ID by name including IPv6, it is intercepting HTTPS, generally a fine setup.
See https://www.snbforums.com/threads/merlin-dnsmasq-pi-hole-accurate-device-names-how-to.69096/
which post's directions are you following within this thread you shared the link to? Are you running @dave14305 's directions?I'm running this configuration on a Pi and it works well. I have all devices ID by name including IPv6, it is intercepting HTTPS, generally a fine setup.
Yes, those directions.which post's directions are you following within this thread you shared the link to? Are you running @dave14305 's directions?
I may be apt to give them a try?
Welcome To SNBForums
