pixelserv pixelserv - A Better One-pixel Webserver for Adblock
AB-Solution has option to install.
I did not know there was any reason to run two pixelserv within a network, as long as you are running on main router.
AB-Solution dont have option to install two consecutive instances of pixelserv-tls.
And the reason is either load balancing or make the secondary instance act as a filter for rouge domains which failed TLS Handshake for multiple reasons, that way the primary instance stats looks neat.
Unknown TLS handshake errors
Remember slu / uce / uca that we introduced in pixelserv-tls 2.1?
I'm tired of glimpsing my pixelserv.log for suspicious errors. So wrote a little script to do the task for me. The script will skip suppressed (client, server) pairs, and highlight any new unknown cert/unknown CA entries for the day.
It sends an email report. See screenshot below. If there are new entries, they'll be listed in place of the "hooray" message.
The script has following requirements:
  1. You enable minimum log LEVEL 2 in pixelserv-tls.
  2. Set up a cron job for this script to run at the end of the day (23:59 recommended)
  3. Supply your own email sending script that takes two arguments: 1st arg subject as in double quotes. 2nd arg body of email from a file.
Any privacy conscious ppl want to try...pls let me know. :)
Today's run with layout change and a new feature.
If "New breaks (uce/uca)" is non zero, the corresponding section of details will be shown as before.
The new feature of showing "New certs (slm)" was suggested by @Asad Ali. Looks interesting!
Hi pixelserv users,
I don't have broken sites but since installing pixelserv-tls thru ab-solution, i'm finding my ESET Anti-Virus warns me many times every day about untrusted certificates. Whenever i check the certificate, it is issued by Pixelserv.
Should i uninstall pixelserv? I'm not noticing any performance boosts with it on. However i may not be understanding how to properly use it, athough it is on the default setup when you install it via Ab-Solution.
Thanks,
gwopman
You're lucky that I looked at it before :)
Try to put your pixelserv ip in ESET's exception list. This post has more details: https://www.snbforums.com/threads/ab-solution-webpage-antivirus-problems.46817/page-3#post-408752
That particular thread was not conclusive about the result though. Hence, would appreciate if you could try and provide feedback.
Your timing couldn't have been more perfect! I did check the first and last pages of the thread quickly so i missed that. I'll white list the pixelserv IP in ESET for now, and report back whether everything's perfect or any problems after i've tried it out for a little while.
I'm getting lots of handshake failed logs for my iphone even though certificate is installed. Safari is OK but when I use apps like instagram I get these. any comments?
Jun 22 00:29:31 Ev pixelserv-tls: handshake failed: client 172.24.5.8:63574 server (null). Lib(20) Func(118) Reason(252)
Jun 22 00:29:39 Ev pixelserv-tls: handshake failed: client 172.24.5.8:63575 server (null). Lib(20) Func(118) Reason(252)
Jun 22 00:29:39 Ev pixelserv-tls: handshake failed: client 172.24.5.8:63576 server (null). Lib(20) Func(118) Reason(252)
Jun 22 00:29:39 Ev pixelserv-tls: handshake failed: client 172.24.5.8:63577 server (null). Lib(20) Func(118) Reason(252)
Jun 22 00:29:51 Ev pixelserv-tls: handshake failed: client 172.24.5.8:63578 server (null). Lib(20) Func(118) Reason(252)
Block graph.instagram.com manually in your hosts file to 0.0.0.0 and you'll see improvement.
These are known as "other TLS handshake errors" that in v2.1.1 were logged on LEVEL 5 and moved to LEVEL 2 in 2.1.2.
252 indicates "unknown protocol". I suspect Instagram is doing something unusual to protect traffics between its client and server.
Even the server domain isn't available that indicates failure happens pretty early in the handshake stage.
I'm sure this is covered somewhere, but I havne't been able to track down the post. Is this message OK? As far as I know, it's blocked by ab-solution (which is how I'd like it to be)
pixelserv-tls[23910]: handshake failed: unknown cert. client 10.14.16.100:38381 server ssl.google-analytics.com
@kvic What is the acceptable number for "slc" ? Also any way to trace the cause of "slc" higher than "slh" ?
@kvic
I have had your suggestions in place regarding ESET Security on Windows for 4-5 days now,
i have noticed as soon as i whitelisted the pixelserv IP in ESET the internet performance on that machine was even faster than before.
It makes sense since my other devices (PS4, Roku TV, iPhone) all were not slowed down like the PC with ESET.
So i am considering the problem "fixed".
Now i will update to the newest version. :)
BTW i have not checked my failed logs but I have been using a lot of Instagram with no problem
It's perfectly fine. Your client checks server certificate against its hardcoded local copy. It sees difference and refuses to proceed further and send actual data. The client doesn't want others to inspect what data actually being sent to the real server.
Also, "unknown cert" corresponds to +1 in uce count. "unknown CA" corresponds to +1 in uca count.
There is no limit for slc. Any number is valid and acceptable. It's also not unexpected that slc >> slh.
If you have a few "rogue" clients, slc will keep increasing. For example, recently I found Instagram uses a twisted protocol to send data between its client and server graph.instagram.com that had puzzled me for a long time since the beta of v2.1.
It turns out graph.instagram.com uses TLSv1.2 but a cipher from TLSv1.3. No standard server can accept such connection except Facebook's twisted implementation!
Alighty! Thanks and is such entries (slc) show/logged in any log level?
All are logged in LEVEL 2 in v2.1.2.
For example, Instagram will look like this:
Jun 24 14:42:25 Phaeo pixelserv-tls[25623]: handshake failed: client 192.168.1.111:58931 server graph.instagram.com. Lib(20)         Func(138) Reason(193)
No solution atm. So I continue to send graph.instagram.com to 0.0.0.0 (or a 2nd instance of pixelserv-tls if you have).
You talking about these entries?
 handshake failed: client 192.168.1.10:59653 server stats.appsflyer.com. Lib(20) Func(138) Reason(227)
Aren't they logged in "slu" ?
L Is Diversion better than NextDNS, PiHole or AdGuard Home? Asuswrt-Merlin AddOns 27
