@mstombs might be good to review the code then so far i havent noticed any bugs in pixelserv tls so keep up the good work on pixelserv cause i need it for my minimalist adblockr called ublockr
Code:ls /opt/var/cache/pixelserv/ | wc -l 107
signal(SIGUSR1, SIG_DFL); // default is ignore?
Great, thanks. For my education - I know nothing about pthreads - why do we still use a fork for the reply handler?
https://github.com/kvic-z/pixelserv-tls/blob/master/pixelserv.c#L584
i do just backup jffs....and there are stored just openvpn keys and certs....did you store your cert is /jffs ?
ASUSWRT-Merlin RT-AC68U 380.59-beta1-g3b6a743 Sun Apr 24 17:20:10 UTC 2016
admin@RT-AC68U:/tmp/home/root# opkg install pixelserv-tls
Installing pixelserv-tls (V35.HZ12.Kh-20160313-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/pixelserv-tls_V35.HZ12.Kh-20160313-1_armv7soft.ipk.
Collected errors:
* opkg_download: Failed to download http://pkg.entware.net/binaries/armv7/pixelserv-tls_V35.HZ12.Kh-20160313-1_armv7soft.ipk, wget returned 4.
* opkg_install_pkg: Failed to download pixelserv-tls. Perhaps you need to run 'opkg update'?
* opkg_install_cmd: Cannot install package pixelserv-tls.
admin@RT-AC68U:/tmp/home/root# opkg update
Downloading http://pkg.entware.net/binaries/armv7/Packages.gz.
Collected errors:
* opkg_download: Failed to download http://pkg.entware.net/binaries/armv7/Packages.gz, wget returned 4.
it is ok now.....Some IPs/subnets was blocked during last DDoS attack. See how to use proxy for opkg.
AiCloud use port 443 for default....but i would like to use that port for https....any solution for this?
Apr 27 22:22:34 pixelserv[5405]: Sending HTTP 501 response for unknown HTTP method or non-SSL, non-HTTP request: CONNECT
PIXIP=192.168.66.254
ifconfig br0:0 $PIXIP up
bad: # of unknown HTTP methods 568
pixelserv-tls version: V35.HZ12.Kh compiled: Mar 26 2016 12:16:28 options: 192.168.66.254 -p 80 -p 81 -p 8080 -p 8081 -k 443 -o 2
uts: Uptime 4 days 12:09
req: Total # of requests 8393
avg: Avg size of reqs 939 bytes
rmx: Max size of reqs 5707 bytes
tav: Avg process time 437 ms
tmx: Max process time 3970 ms
err: # of error reqs 0
tmo: # of client timeout 507
cls: # of client shutdown 4135
nou: # of reqs w/o URL 0
pth: # of invalid URL 0
nfe: # of missing file ext 1264
ufe: # of unknown file ext 51
gif: # of GIF reqs 63
bad: # of unknown HTTP methods 0
txt: # of TXT reqs 1192
jpg: # of JPG reqs 0
png: # of PNG reqs 0
swf: # of SWF reqs 0
ico: # of ICO reqs 2
slh: # of HTTPS /w a good cert 3243
slm: # of HTTPS w/o a cert 11
sle: # of HTTPS /w a bad cert 0
slu: # of unrecognized HTTPS 1044
sta: # of HTML stats 2
stt: # of text stats 1
204: # of HTTP/204 (no content) 0
rdr: # of redirects 1169
pst: # of POST method 6
hed: # of HEAD method 0
log: access log enabled (0=no 1=yes) 0
Apr 28 22:30:26 pixelserv[6419]: Sending HTTP 501 response for unknown HTTP method or non-SSL, non-HTTP request: CONNECT
Apr 28 22:30:26 pixelserv[6419]: ( 9) 192.168.1.104: ads.mopub.com CONNECT ads.mopub.com:443 HTTP/1.1
Thread starter | Title | Forum | Replies | Date |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 27 |
Welcome To SNBForums
