M
M@rco
Guest
Don't forget to make good use of the daily report.
Ehm, what daily report?
By the way, please clear your browser cache to see that helps.
For people can't see full pic, check if "postimg.cc" is in your blind list.
About your new issue...DNS based adblock to some extent is playing a Russian roulette really.
If one of them doesn't load (doesn't matter hitting 0.0.0.0 or pixelserv-tls), you maybe lucky to get stunted i.e. getting some weird issue. Sounds like you run into this case. For many reasons, I don't want to discuss further since it's regarding this forum's website.
What you can do is open your browser's Web Inspector, and then follow the below guide to figure out what domains to whitelist in your script:
Btw, about your issue on intermediate CA, what's the content of your ca.crt?
As requested:
Screenshot taken again after 5 minutes for comparison.
Ehm, what daily report?Is this already available to the public?
Yes please!Quite a few people have been using the beta report. If you want, I can add you to the list too.
I think you are onto something here and this has been where I have been focusing.
Let me say that I have *NOT* removed the default whitelist entries from AB/Diversion that are there to support SNB.
I'm not looking at getting around supporting this site - however it does appear perhaps that those entries are not complete.
It does seem that when certain ads get blocked here it is sending the site into a downward spiral eating up GB of RAM.
I'll report some more on this in a bit, but I want to do more tests and ask a few more pointed questions.
BTW - is there a delay on configuring the logging parameter and when it takes effect? I had configured it on my end (tried every level up to 5) and wasn't getting anything. Then, when I was about to mention the issue here a few minutes later I checked back in syslog and events were flowing.
I don't think I have an issue with my intermediate CA. I'm pretty sure I was mistaken/confused when viewing a generated cert directly from the cert file instead of it being served through pixelserv.
My ca.crt contains the certificate both to my intermediate and my root CA. Thus, when it serves the generated certs the chain can be established to my trusted root.
However, if I copy the generated cert and view it directly via Windows (not through pixelserv) it shows it can't be authenticated - likely because the entire cert chain isn't being supplied (and I don't have the intermediate installed on my computer).
I'm pretty sure this is normal behavior and for all intents and purposes it appears my custom certs are working fine.
I guess I thought it a little strange that it couldn't use my custom generated cert - but the end result gives me more or less the same functionality. It is a little messier with multiple certs, but since they are dynamically generated and are ok being volatile it's good with me!
I notice that when pixelserv starts it caches a cert with my pixelserv ip
i dont understand what this is for .... can anyone enlighten me?Code:Aug 27 21:14:38 RT-AC68U-4690 pixelserv-tls[4500]: sslctx_tbl_load: 10.10.10.3
lol... Unfortunately no luck with the amazon app. I use amazon canada. I tried whitelisting everything again and no luck. I even added fls-na.amazon.ca
Website works fine though. Its only the app. Same with my bank's app. The website works fine, but not the app. I will mess around with my bank's app a bit later tonight see if I can do anything about it.
I have the same problem, did you find a solution for Amazon Canada?
fls-na.amazon.com
fls-eu.amazon.co.uk
Add these entries to your adblock script's whitelist
Code:fls-na.amazon.com fls-eu.amazon.co.uk
Restart dnsmasq on your router. Reboot your client PC or smartphone. Issue should be fixed.
I will try those tonight and I will let you know, I'm also having the same issues with my Desjardins Mobile apps. if someone have any clue...
Sorry, i don't know what app that is.
In case you don't hear back from anyone or would like to be the first to contribute on this one, here is the HOW-TO with minimal guess work.
https://github.com/kvic-z/pixelserv...ut-domain(s)-to-whitelist-on-a-broken-website
Hello,
i'm the http://my pixelserv ip/log=4 but i get a blank screen, I can get my stats from the servstat webpage... This is running on my 3100 Asus router with Merlin 384.7 Alpha 2
Any suggestion?
Hello,
Any suggestion?
I think his confusion was he thought the would see output to the browser page when sending the log=4 command.pixelserv-tls sends any messages to system logger close to realtime. Here on my 56U with 380.66 + syslog-ng (from Entware that replaced firmware's syslog), logs appear immediately.
Since two users saw the same behaviour, I would guess some default behaviour in router firmware might have changed in the past year or two that cause the delay.
Any syslog-ng users see such delay by the way?
He didn't know to check in syslog. I OTOH was actually not seeing anything out to syslog until a delay. I have reloaded my device since then and will check it again when I have a chance.
Thread starter | Title | Forum | Replies | Date |
C | Diversion Pixelserv replacement | Asuswrt-Merlin AddOns | 2 | |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 27 |
Welcome To SNBForums
