thelonelycoder
Part of the Furniture
There's that number again. I hope my code is more accurate.Yep, you do need pillow time for sure because it's iOS 13 [emoji16][emoji16]
Just catching up.
What could possibly be more important than working on Diversion?Real life interferes, Diversion update has to wait![]()
Looks like iOS 13 had made it to Thailand iPhones. Friend of mine posted this morning.
uiDivStats - WebUI for Diversion statisticsHello,
I think I have a problem with pixelserv-tls. It never seemed to work...
Diversion is updated to 4.1.4 and Pixelserv is started and running, I have the Pixelserv CA certificated installed in the Windows Trusted cert store.
I have also installed uiDivStats and the Pixelserv statistics report shows 404 Not Found.
Perhaps someone knows what I did wrong?
Thank you.
New version of uiDivStats available.
You enabled Access Restriction in Administration/System after the Diversion installation.Thank you for the notice, I have updated uiDivStats to the latest version 1.2.1, but the Pixelserv Statistics Report section still shows 404 Not found...
Well... I'm locked outside...You enabled Access Restriction in Administration/System after the Diversion installation.
Diversion checks for it during installation but not afterwards.
Add a rule with "Destination IP" being your pixelserv-tls IP and the "Access Type" being "Web UI" then hit "Apply.
It does check it now, I've silently pushed an update that checks if pixelserv-tls is in the Access rule list.You enabled Access Restriction in Administration/System after the Diversion installation.
Well, that was not a very good idea. I did not ask you to enable it, just add the rule IF Access restriction IS enabled.Well... I'm locked outside...
The Access Restriction was off and I just added one single rule to allow pixelserv to webui...
Now I can't connect to the WebUI nor SSH.
Is there a way to undo this without resetting the router?
I didn't think it through...Well, that was not a very good idea. I did not ask you to enable it, just add the rule IF Access restriction IS enabled.
I think what might work is this since the pixelserv-tls IP has access to the Webui:Is there a way to undo this without resetting the router?
No need to rush for an update just yet, iOS 13.1 is releasing on 24th.
1. Unplug Router from power source
2. Remove attached USB device(s)
3. Power up router
4. Manually set one of your devices to the pixelserv-tls IP
5. Log in to the Webui
6. Remove access restriction
7. Disconnect that device with the manual IP
8. Unplug Router from power source
9. Plug in USB device(s)
10. Power up router
Sorry for your troubles, but the access restriction is the most obvious cause from my point of view for your original problem.Thank you, I was thinking of the same solution.
The only USB device connected is the one where Entware is installed.
I can't do this now, because I'm away from the router, but I'll do it when I return.
Cheers!
Thread starter | Title | Forum | Replies | Date |
C | Diversion Pixelserv replacement | Asuswrt-Merlin AddOns | 2 | |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 27 |
Welcome To SNBForums
