This is no beta, Entware will have the updated packages with their next regular update.Now a technologically challenged person like me just needs it to be automatically updateable via amtm.
The Lonely Coder will assuredly get to this at some time, but coffee must first be had..........![]()
Can somebody write step by step how to install a pixelserv on the raspberry_pi with pi-hole or adguard home?
Do these help Install pixelsrv-tls on Raspberry Pi together with Making pixelsrv-tls work with Pi-hole on Raspberry PiCan somebody write step by step how to install a pixelserv on the raspberry_pi with pi-hole or adguard home?
Let it be noted that users are experiencing issues installing using curl -o to download the file. I switched DL instructions to use wget instead.Do these help Install pixelsrv-tls on Raspberry Pi together with Making pixelsrv-tls work with Pi-hole on Raspberry Pi
I recommend not running them together unless you plan on using pihole solely for DHCP and Web UI features. Pixelserv-tls has no need for pihole. just as pihole has no need for pixelserv-tls, mixing the two is one big redundant mess.Can somebody write step by step how to install a pixelserv on the raspberry_pi with pi-hole or adguard home?
Very good feature , but I do not know where else can ask.
While most browsers these days support TLS1.3 - TLS downgrade attacks are still in the wild and could potentially cause some damage
I get different results with 2.3.1 installed.Can you please remove Obsolete: SEED + 128+256 Bit CBC cipher?
Testing protocols via sockets except SPDY+HTTP2
SSLv2 not offered (OK)
SSLv3 not offered (OK)
TLS 1 offered
TLS 1.1 not offered
TLS 1.2 offered (OK)
SPDY/NPN not offered
HTTP2/ALPN not offered
Testing ~standard cipher categories
NULL ciphers (no encryption) not offered (OK)
Anonymous NULL Ciphers (no authentication) not offered (OK)
Export ciphers (w/o ADH+NULL) not offered (OK)
LOW: 64 Bit + DES encryption (w/o export) not offered (OK)
Weak 128 Bit ciphers (SEED, IDEA, RC[2,4]) not offered (OK)
Triple DES Ciphers (Medium) not offered (OK)
High encryption (AES+Camellia, no AEAD) offered (OK)
Strong encryption (AEAD ciphers) offered (OK)Testing vulnerabilities
Heartbleed (CVE-2014-0160) not vulnerable (OK), no heartbeat extension
CCS (CVE-2014-0224) not vulnerable (OK)
Ticketbleed (CVE-2016-9244), experiment. not vulnerable (OK), no session tickets
Secure Renegotiation (CVE-2009-3555) VULNERABLE (NOT ok)
Secure Client-Initiated Renegotiation not vulnerable (OK)
CRIME, TLS (CVE-2012-4929) not vulnerable (OK)
BREACH (CVE-2013-3587) no HTTP compression (OK) - only supplied "/" tested
POODLE, SSL (CVE-2014-3566) not vulnerable (OK)
TLS_FALLBACK_SCSV (RFC 7507) No fallback possible, TLS 1.2 is the only protocol (OK)
SWEET32 (CVE-2016-2183, CVE-2016-6329) not vulnerable (OK)
FREAK (CVE-2015-0204) not vulnerable (OK)
DROWN (CVE-2016-0800, CVE-2016-0703) not vulnerable on this host and port (OK)
Thread starter | Title | Forum | Replies | Date |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 29 |
Welcome To SNBForums
