Likely not a Diversion/pixelserv-tls problem.I nuked (see @L&LD) the 87U, and started all over with 13_5. I reclaimed the DDNS address, formatted the drive, reformatted the drive and added only Diversion and pixelserv, and Skynet, and for about 10 minutes it worked, and then ads came back. (I haven't experienced this in a few years. Wow.)
It's simply checking the model nvram variable, which DSL-AC68U is not a part of the original script. If you're adventurous, you can download it from here and change or remove the model check lines (or delete line 39 "exit 0").I have just nuked and rebuilt from scratch a DSL-AC68U running @GNUton firmware version 384.17 [started with stock firmware latest build for this router under factory reset - then dirty flash to 384.17 ... followed by factory reset etc etc ala @L&LD ]
WHAT a pleasure to have amtm built into fw ... and all the scripts provided within it. Easiest nuke rebuild I have experienced...
However ... I have hit one hurdle ... amtm option "ps - use pixelserv-tls CA for Webui" fails with this message ...
Did everything required as per screen [test pixelserv CA cert etc] - and am certain this "ps" function used to work on DSL-AC68U's [have 3 in the field and at least 2 of them have valid certs from pixelserv-tls CA for DDNS access].
Just not sure who the "me" is in the message "Please contact me for assistance" above. I see @kvic left the building on 25 March 2019 - so doubt that I will get any help from him. @thelonelycoder @Jack Yaz @GNUtonmaybe? Thanks in anticipation ...
“me” refers to kvic, this script is pulled from his server.Just not sure who the "me" is in the message "Please contact me for assistance" above. I see @kvic left the building on 25 March 2019 - so doubt that I will get any help from him. @thelonelycoder @Jack Yaz @GNUtonmaybe? Thanks in anticipation ...
Is the model name returned with the following exactly "DSL-AC68U" or does it differ?I have just nuked and rebuilt from scratch a DSL-AC68U running @GNUton firmware version 384.17 [started with stock firmware latest build for this router under factory reset - then dirty flash to 384.17 ... followed by factory reset etc etc ala @L&LD ]
nvram get model
2.3.1 is on github with a license:Bad idea, there's no license mentioned in that script.
Not for the config-webgui.sh tough. AFAIK this script is hosted only on his web-server.2.3.1 is on github with a license:
https://github.com/kvic-z/pixelserv-tls/blob/master/LICENSE
Ah, if only one would scroll down in that file:2.3.1 is on github with a license:
PERMISSION IS GRANTED TO USE OR MODIFY THIS SCRIPT FREE OF CHARGE
AS LONG AS THE ABOVE COPYRIGHT NOTICE REMAINS INTACT.
NO WARRANTY IS PROVIDED. PLEASE DECIDE AND USE AT YOUR OWN RISK.
I'll add a question if the concerned line should be replaced with the current list of supported Asuswrt-Merlin models instead.
(c) 2018-19 kvic (aka kvic-z@github)
https://kazoo.ga/pixelserv-tls/
Beat me to itAh, if only one would scroll down in that file:
Code:PERMISSION IS GRANTED TO USE OR MODIFY THIS SCRIPT FREE OF CHARGE AS LONG AS THE ABOVE COPYRIGHT NOTICE REMAINS INTACT. NO WARRANTY IS PROVIDED. PLEASE DECIDE AND USE AT YOUR OWN RISK.
I’m not even certain why there is a model check. If a specific feature is needed, it should be verified with rc_support.It is also possible to just add the model to the list that is in this script?
But this script is old now. I won’t throw (any more) stones.
RT-AC56
RT-AC68
DSL-AC68U
RT-AC87
RT-AC3100
RT-AC88
RT-AC3200
RT-AC5300
RT-AC86U
RT-AX88U
RT-AC88U
RT-AX56U
RT-AX58U
RT-AX3000
RT-AC66U_B1 (same firmware as the RT-AC68U)
RT-AC68U (including revisions C1 and E1)
RT-AC68P (same firmware as RT-AC68U)
RT-AC68UF (same firmware as RT-AC68U)
RT-AC87
RT-AC3200
RT-AC88U
RT-AC3100
RT-AC5300
RT-AC1900 (same firmware as RT-AC68U)
RT-AC1900P (same firmware as RT-AC68U)
RT-AC86U (starting with version 382.1)
RT-AC2900 (same firmware as RT-AC86U)
RT-AX88U
RT-AX56U
RT-AX58U
RT-AX3000
Thread starter | Title | Forum | Replies | Date |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 29 |
Welcome To SNBForums
