pixelserv pixelserv - A Better One-pixel Webserver for Adblock
5 days and counting....
pixelserv-tls: v2.0.0-rc1 compiled: Nov 26 2017 20:53:17 options: 192.168.1.2
449490 uts, 1 log, 1 kcc, 42 kmx, 1.55 kvg, 220 krq, 23191 req, 953 avg, 28556 rmx, 25 tav, 3194 tmx, 12253 slh, 115 slm, 0 sle, 5432 slc, 350 slu, 2653 nfe, 29 gif, 3 ico, 1396 txt, 0 jpg, 2 png, 0 swf, 13 sta, 7 stt, 59 ufe, 53 opt, 167 pst, 0 hed, 654 rdr, 0 nou, 0 pth, 0 204, 0 bad, 130 tmo, 5509 cls, 8107 cly, 0 clt, 0 err
For some reason, pixelserv-tls becomes unresponsive after 2 hours run. Already set - o 10. Will turn on - l 5 on the next restart.
When it happens again, can you issue "killall -SIGUSR1 pixelserv-tls" to dump the servstats to syslog. Also try "ping <your pixelserv-tls ip>" and see if any response.
Quickly share a piece of finding:
  • ver. KK with select_timeout = 1s gives best speed
  • v2 is the opposite. 10s yields better speed than 1s.
For v2, perhaps there is an optimal value between 1s and keepalive_timeout. I only tried 1s, 5s, 10s and keepalive_timeout in which 10s gives best speed.
This can be explained by the change in event loop in v2. So you might want to add '-o 10' to your CLI option.
Quite many ppl downloaded v2.0.0-rc1 (and assume you're happily running it). Does any of your v2 get into "stuck" or "hang" state?
I haven’t been paying very close attention but I haven’t noticed any problems. That said, I’ve only been running pixelserv with the default timeout options since 2.0.0-rc1 dropped. Prior to v2 I used -o 1.
When pixelserv-tls gets into "stuck" or "hang" state, browsing on clients will slow down to a crawl. It's very noticeable. That's also why I'm thinking it might not be a common issue since I don't see many complaints in this thread. lol
I only saw it once during stress test i.e. after 18 million requests in the middle of a KL test build. Didn't pay much attention on the issue back then as I thought home routers eventually disintegrate into such state under heavy workload.
I've been in touch with tom- and protik offline about this issue. @Protik was able to reproduce with '-o 1' a few times and i got some useful traces. Though essentially it points to pixelserv-tls stuck in an abnormal state which very likely caused by bugs in kernels.
Btw while looking at the issue, I found '-o 10' is much better speed for v2. @jrmwvu04, you shall switch to use it. I'll default back to 10s or perhaps another higher & optimal value in a future release.
I installed fork 29A9 and made the change to '-o 10' just beforehand. Will let it run for a bit and see how it goes.
v2 beats the previous version in speed. Confirmed. :)
A tabulated summary of "-o 10" vs "-o 1" in v2 and against the previous version.
The same finding shared yesterday but put in a blog post.
I have updated -o 15 on the second try.
Dec 5 21:50:00 pixelserv-tls[8999]: pixelserv-tls: v2.0.0-rc1 compiled: Nov 26 2017 20:53:17 options: 192.168.1.2 -o 15 -l 5
Dec 5 21:50:00 pixelserv-tls[8999]: Listening on :192.168.1.2:80
Dec 5 21:50:00 pixelserv-tls[8999]: Listening on :192.168.1.2:443
Dec 6 19:56:17 pixelserv-tls[8999]: 79578 uts, 5 log, 283 kcc, 283 kmx, 2.03 kvg, 29 krq, 5179 req, 782 avg, 3313 rmx, 59 tav, 11625 tmx, 32 slh, 58 slm, 0 sle, 2930 slc, 324 slu, 91 nfe, 2 gif, 42 ico, 18 txt, 0 jpg, 0 png, 0 swf, 43 sta, 3 stt, 4 ufe, 0 opt, 216 pst, 0 hed, 5 rdr, 0 nou, 0 pth, 0 204, 4 bad, 12 tmo, 3073 cls, 0 cly, 0 clt, 0 err
Want to add: There was ping response from pixelserv-tls ip though html stats was not responsive.
That's same with my earlier problem. Rebooting router or running "pixelserv-tls <listening ip>" fixed that on my router.
@quant88 @Protik @tom-
pls use the install-beta.sh script (or otherwise) to get v2.0.1-rc1. It tries to mitigate the "stuck" issue with a possible cause I could dream of last night.
Changes in v2.0.1-rc1
  • mitigate "stuck" issue
  • select_timeout default to 10s
I have tried with new beta but still faced stuck issue. Let me know which other tests you may need. I have installed pixelserv-tls in 2 homes - The other AP (also a Ac88u) is running smoothly with the first beta though. The one seeing the issue is connected with many clients and 1-2 repeaters.
I want to Thank you for the amazing work!
Dec 7 06:59:58 pixelserv-tls[656]: 31059 uts, 1 log, 4 kcc, 30 kmx, 2.09 kvg, 17 krq, 3147 req, 1054 avg, 3315 rmx, 26 tav, 7592 tmx, 41 slh, 53 slm, 1 sle, 1888 slc, 172 slu, 31 nfe, 0 gif, 14 ico, 2 txt, 0 jpg, 0 png, 0 swf, 16 sta, 0 stt, 3 ufe, 0 opt, 156 pst, 0 hed, 0 rdr, 0 nou, 0 pth, 0 204, 0 bad, 7 tmo, 1924 cls, 0 cly, 0 clt, 0 err
I will save this link... I got stuck this evening, and I could not browse to this link to get the -SIGUSR1 command to post the stats.
Restarting the service immediately restored normal browsing action on my network.
I'm repeating my stress test. After 140 million requests and still no luck getting stuck..
I started a conversation with @quant88 @baltosml to get more traces.
Hi kvic,
I'm having the same problem with v2.0.1-rc1 hanging after a few hours of use on an N66u. I decided to compile from source and run on a Raspberry Pi to see if the same problem occurs, in the hope that there might be some more tools available to debug the problem. Sure enough, after a few hours of running it appears to have hung - I can still ping the ip address/telnet on port 443, but attempting to access the servstats page hangs, and opening other websites is slow.
I ran an strace on the process and found the following:
root@raspberrypi:/var/log# strace -p 9869
Process 9869 attached
read(9,
lsof -i^CProcess 9869 detached
...so it appears to be hanging on read.
I ran lsof and netstat to see what files/sockets were open:
root@raspberrypi:/proc/9869# lsof -p 9869
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pixelserv 9869 nobody cwd DIR 179,2 4096 2 /
pixelserv 9869 nobody rtd DIR 179,2 4096 2 /
pixelserv 9869 nobody txt REG 179,2 39848 1792 /usr/local/bin/pixelserv-tls
pixelserv 9869 nobody mem REG 179,2 46820 1969 /lib/arm-linux-gnueabihf/libnss_files-2.19.so
pixelserv 9869 nobody mem REG 179,2 38612 1977 /lib/arm-linux-gnueabihf/libnss_nis-2.19.so
pixelserv 9869 nobody mem REG 179,2 71628 1966 /lib/arm-linux-gnueabihf/libnsl-2.19.so
pixelserv 9869 nobody mem REG 179,2 30592 1967 /lib/arm-linux-gnueabihf/libnss_compat-2.19.so
pixelserv 9869 nobody mem REG 179,2 9820 1940 /lib/arm-linux-gnueabihf/libdl-2.19.so
pixelserv 9869 nobody mem REG 179,2 1242776 1932 /lib/arm-linux-gnueabihf/libc-2.19.so
pixelserv 9869 nobody mem REG 179,2 1418532 41716 /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
pixelserv 9869 nobody mem REG 179,2 300868 41717 /usr/lib/arm-linux-gnueabihf/libssl.so.1.0.0
pixelserv 9869 nobody mem REG 179,2 122308 1992 /lib/arm-linux-gnueabihf/libpthread-2.19.so
pixelserv 9869 nobody mem REG 179,2 18920 10032 /usr/lib/arm-linux-gnueabihf/libarmmem.so
pixelserv 9869 nobody mem REG 179,2 134448 1897 /lib/arm-linux-gnueabihf/ld-2.19.so
pixelserv 9869 nobody 0u CHR 1,3 0t0 1029 /dev/null
pixelserv 9869 nobody 1u CHR 1,3 0t0 1029 /dev/null
pixelserv 9869 nobody 2u CHR 1,3 0t0 1029 /dev/null
pixelserv 9869 nobody 3u unix 0xb91f8c00 0t0 1395555 socket
pixelserv 9869 nobody 4u IPv4 1395558 0t0 TCP *:81 (LISTEN)
pixelserv 9869 nobody 5r FIFO 0,10 0t0 1395560 pipe
pixelserv 9869 nobody 6u IPv4 1395559 0t0 TCP *:https (LISTEN)
pixelserv 9869 nobody 7w FIFO 0,10 0t0 1395560 pipe
pixelserv 9869 nobody 9u IPv4 1466930 0t0 TCP 192.168.1.13:https->android-dad30b14da36932a:58928 (ESTABLISHED)
root@raspberrypi:/proc# netstat -anp | grep 9869
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 9869/pixelserv-tls
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 9869/pixelserv-tls
tcp 0 0 192.168.1.13:443 192.168.1.207:58928 ESTABLISHED 9869/pixelserv-tls
unix 2 [ ] DGRAM 1395555 9869/pixelserv-tls
...so I'd assume it is hanging attempting read from the following socket:
I attached gdb to the pixelserv process and ran the following to kill this socket:
(gdb) p close(9)
$1 = 0
(gdb) quit
...and sure enough, pixelserv started working again!
Hopefully be of use...
Cheers,
Dave.
@froggy666uk Thank you! This is helpful.
The output of strace/lsof is similar to what I got from @Protik.
I suspect the issue is that read() performs on file descriptor 9 which is a TCP socket. It's expected to read from a FIFO pipe id 5.
Indeed if that's the case, I haven't figured out how it gets into such a weird state. Do u get a chance to try v2.0.1-rc1 and does it stall at the same place?
The build I was using on my n66u was v2.0.0-rc1, my raspberry pi build was based on the github master branch. Have your latest v2.0.1-rc1 changes been committed to github master?
Could it be a problem peculiar to android devices? Have you tested using android?
Anything else I could look at on my raspberry pi that might help next time it happens? :)
