Or the other way round. How often was a purge required to make room.I had the same thought looking at it. I wondered if it was simply a sanity check.
More than 11h uptime with pixelserv-tls: v2.1.0-test.2 on 64bit merged entware with ab-solution on a 86U. At first pixelserv would crashed after 5 mins or so... After many trials and errors I got it fixed. I don't know what exactly fixed it but on my last attempt I 'Purge generated pixelserv certificate" in ab-solution.
sh -c "$(wget -qO - https://kazoo.ga/pixelserv-tls/install-beta.sh)"
Installed test3, so far so good
test3 working great on three routers here, no issues so far. Neither did test2 on the 86U but I had to restart it often for tests that have nothing to do with pixelserv-tls.Nice. Pls try your best to abuse it, crash it and report abnormal RAM usage if any.
slh 467 # of accepted HTTPS requests
slm 0 # of rejected HTTPS requests (missing certificate)
sle 0 # of rejected HTTPS requests (certificate available but bad)
slc 161 # of dropped HTTPS requests (client disconnect without sending any request)
slu 0 # of dropped HTTPS requests (unknown error)
sct 67 ssl cache: # of cached cert
sch 343 ssl cache: # of cache hit
scm 67 ssl cache: # of cache miss
scp 0 ssl cache: # of purge to free up slots
slh 1177 # of accepted HTTPS requests
slm 95 # of rejected HTTPS requests (missing certificate)
slc 544 # of dropped HTTPS requests (client disconnect without sending any request)
slu 651 # of dropped HTTPS requests (unknown error)
sct 63 ssl cache: # of cached cert
sch 1352 ssl cache: # of cache hit
scm 158 ssl cache: # of cache miss
slh 5879 # of accepted HTTPS requests
slm 4 # of rejected HTTPS requests (missing certificate)
slc 916 # of dropped HTTPS requests (client disconnect without sending any request)
slu 300 # of dropped HTTPS requests (unknown error)
sct 69 ssl cache: # of cached cert
sch 2271 ssl cache: # of cache hit
scm 73 ssl cache: # of cache miss
Does seem to be the case.Seems scm = sct + slm ?
slh 148 # of accepted HTTPS requests
slm 42 # of rejected HTTPS requests (missing certificate)
slc 962 # of dropped HTTPS requests (client disconnect without sending any request)
slu 2096 # of dropped HTTPS requests (unknown error)
sct 58 ssl cache: # of cached cert
sch 33492 ssl cache: # of cache hit
scm 100 ssl cache: # of cache miss
For a more aggressive test, processing times and especially tav is exceptionally low. I’ll let it go organically as I have little time to test today.
Thread starter | Title | Forum | Replies | Date |
C | Diversion Pixelserv replacement | Asuswrt-Merlin AddOns | 2 | |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 27 |
Welcome To SNBForums
