jrmwvu04
This is thoroughly fantastic. Tested on iOS 11.2.6 and macOSNotably we now have URI "/ca.crt" to download and import your Pixelserv CA certificate on client devices.
I know it's not hip or current to talk about version Kk, but I have set up a family member with a load out that doesn't get fiddled with too often and I decided on a whim to check up on it.
pixelserv-tls 2.1.0-test.7 (compiled: Mar 14 2018 21:00:59) options: 192.168.1.2
50399 uts, 1 log, 1 kcc, 9 kmx, 4.13 kvg, 2678 krq, 3582 req, 1039 avg, 6202 rmx, 1 tav, 147 tmx, 2780 slh, 6 slm, 0 sle, 309 slc, 476 slu, 55 sct, 740 sch, 5 scm, 0 scp, 1 sst, 38 ssh, 65 ssm, 0 ssp, 2711 nfe, 0 gif, 0 ico, 0 txt, 0 jpg, 0 png, 0 swf, 7 sta, 1 stt, 4 ufe, 0 opt, 19 pst, 0 hed, 3 rdr, 0 nou, 0 pth, 0 204, 0 bad, 0 tmo, 310 cls, 46 cly, 0 clt, 0 err
pixelserv-tls 2.1.0-test.7 (compiled: Mar 14 2018 21:00:59) options: 192.168.2.2 -c 150
uts 0d 16:08 process uptime
log 1 critical (0) error (1) warning (2) notice (3) info (4) debug (5)
kcc 1 number of active service threads
kmx 33 maximum number of service threads
kvg 15.99 average number of requests per service thread
krq 14779 max number of requests by one service thread
req 18104 total # of requests (HTTP, HTTPS, success, failure etc)
avg 657 bytes average size of requests
rmx 5729 bytes largest size of request(s)
tav 18 ms average processing time (per request)
tmx 3142 ms longest processing time (per request)
slh 15094 # of accepted HTTPS requests
slm 1 # of rejected HTTPS requests (missing certificate)
sle 0 # of rejected HTTPS requests (certificate available but bad)
slc 210 # of dropped HTTPS requests (client disconnect without sending any request)
slu 2568 # of dropped HTTPS requests (unknown error)
sct 128 cert cache: # of certs in cache
sch 1424 cert cache: # of reuses of cached certs
scm 16 cert cache: # of misses to find a cert in cache
scp 0 cert cache: # of purges to give room for a new cert
sst 27 sess cache: # of cached TLS sessions (for older non-RFC5077 clients)
ssh 73 sess cache: # of reuses of cached TLS sessions
ssm 69 sess cache: # of misses to find a TLS session in cache
ssp 0 sess cache: # of purges to give room for a new TLS session
Well that's the cat's meow.Btw, has anyone tried importing CA cert on Android using 'http://<your ip>/ca.crt" ?
Works like a champ on Galaxy S8+ running Android 7.x. Simply:Btw, has anyone tried importing CA cert on Android using 'http://<your ip>/ca.crt" ?![]()
You might update the WIKI page for this. It isn't intuitively obvious, and the existing part about emailing the cert to yourself is so much more complicated it will mislead most.
Mar 15 14:48:48 kernel: pixelserv-tls[19008]: unhandled level 2 translation fault (11) at 0x00000020, esr 0x92000006
Mar 15 14:48:48 kernel: pgd = ffffffc010c84000
Mar 15 14:48:48 kernel: [00000020] *pgd=000000000a0b8003, *pud=000000000a0b8003, *pmd=0000000000000000
Mar 15 14:48:48 kernel: CPU: 0 PID: 19008 Comm: pixelserv-tls Tainted: P O 4.1.27 #2
Mar 15 14:48:48 kernel: Hardware name: Broadcom-v8A (DT)
Mar 15 14:48:48 kernel: task: ffffffc015124b80 ti: ffffffc010ce0000 task.ti: ffffffc010ce0000
Mar 15 14:48:48 kernel: PC is at 0x7f7c062284
Mar 15 14:48:48 kernel: LR is at 0x7f7c062428
Mar 15 14:48:48 kernel: pc : [<0000007f7c062284>] lr : [<0000007f7c062428>] pstate: 60000000
Mar 15 14:48:48 kernel: sp : 0000007fcad42d10
Mar 15 14:48:48 kernel: x29: 0000007fcad42d60 x28: 0000000000000000
Mar 15 14:48:48 kernel: x27: 0000000000000009 x26: 0000007f5400ceb0
Mar 15 14:48:48 kernel: x25: 000000003dee8b00 x24: 0000000000000002
Mar 15 14:48:48 kernel: x23: 0000000000000000 x22: 0000000000000009
Mar 15 14:48:48 kernel: x21: 0000007f5400d950 x20: 0000007f5400d950
Mar 15 14:48:48 kernel: x19: 0000000000000000 x18: fb80c3101c40c78e
Mar 15 14:48:48 kernel: x17: 0000000000000000 x16: 000000000000003f
Mar 15 14:48:48 kernel: x15: 0000000000000020 x14: 0000000000000002
Mar 15 14:48:48 kernel: x13: 00000000000004f0 x12: 000000003c27d268
Mar 15 14:48:48 kernel: x11: 0000000000000007 x10: 0000000000000000
Mar 15 14:48:48 kernel: x9 : 000000000000270f x8 : 00000000000000de
Mar 15 14:48:49 kernel: x7 : 0000000000000000 x6 : 0000000000000001
Mar 15 14:48:49 kernel: x5 : 0000007fcad42d2c x4 : 0000007f7bf2e0b0
Mar 15 14:48:49 kernel: x3 : 0000007fcad42d2c x2 : 0000007f5400d950
Mar 15 14:48:49 kernel: x1 : 0000007f5400d950 x0 : 0000000000000000
I wasn't at home more than 12 hours and here the servstats. it's up for more than 30 hours;
http://prntscr.com/irqvg4
Do you have the certificate installed on all your client devices? Your slc is too high in my opinion.
Yes I have but I also use adblocker on my phone and Firefox and probably lots of the request are HTTP. I guess these are the possible reasons.
I think the HTTP requests are not added in slc but I can be wrong.
Thread starter | Title | Forum | Replies | Date |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 29 |
Welcome To SNBForums
