Thank you for your great work!
Also no problems with Opera (51.0.2830.55; x64)
If you happen to have an affinity for Nate Silver, there’s not necessarily any window dressing. pixelserv requests well rocket well into the thousands inside of 30 seconds and one or two page loads in some cases. It’s unlike anything I’ve experienced before.My two instances of 2.1.0-rc.2 over 33 hours...marching on its 2nd day.
n1 is using 8.2MB RAM on RT-56U. n2 is using 6.5MB on ER-X.
Showing a pleasant constraint of no RAM abuse. So far rc.2 puts pixelserv-tls in its best shape ever yet.
(I did no window dressing on the servstats numbers... all from usual and everyday browsing activities. LOL)
Thanks for posting.
slc is a bit too high. I wonder what Apps/clients might have caused that.
slc is after clients having passed TLS handshake. So that means these clients already have CA cert imported. But then somehow they decide to disconnect without sending any requests. And this behaviour repeats frequently in your environment based on the total requests, req and the slu numbers. *puzzled*
pixelserv-tls 2.1.0-rc.2 (compiled: Mar 20 2018 21:11:49) options: 192.168.1.3
uts 1d 00:36 process uptime
log 1 critical (0) error (1) warning (2) notice (3) info (4) debug (5)
kcc 1 number of active service threads
kmx 15 maximum number of service threads
kvg 1.09 average number of requests per service thread
krq 7 max number of requests by one service thread
req 2182 total # of requests (HTTP, HTTPS, success, failure etc)
avg 557 bytes average size of requests
rmx 3178 bytes largest size of request(s)
tav 8 ms average processing time (per request)
tmx 213 ms longest processing time (per request)
slh 296 # of accepted HTTPS requests
slm 0 # of rejected HTTPS requests (missing certificate)
sle 0 # of rejected HTTPS requests (certificate available but bad)
slc 1352 # of dropped HTTPS requests (client disconnect without sending any request)
slu 479 # of dropped HTTPS requests (other TLS handshake errors)
sct 69 cert cache: # of certs in cache
sch 1977 cert cache: # of reuses of cached certs
scm 1 cert cache: # of misses to find a cert in cache
scp 0 cert cache: # of purges to give room for a new cert
sst 4 sess cache: # of cached TLS sessions (for older non-RFC5077 clients)
ssh 197 sess cache: # of reuses of cached TLS sessions
ssm 9 sess cache: # of misses to find a TLS session in cache
ssp 0 sess cache: # of purges to give room for a new TLS session
One item from the blog post of the SSL Labs tests is worth highlighting again and I bet most users might have overlooked. It's the compatibility list of clients that will work with v2.1:
This link from the blog post carries a bigger and clearer screenshot.
So when people are concerned about your client devices compatible with pixelserv-tls or not, simply go and have a check.
pixelserv-tls 2.1.0-rc.2 (compiled: Mar 20 2018 21:11:49) options: 192.168.2.2 -c 150 -l 2
uts 1d 10:19 process uptime
log 2 critical (0) error (1) warning (2) notice (3) info (4) debug (5)
kcc 2 number of active service threads
kmx 42 maximum number of service threads
kvg 1.32 average number of requests per service thread
krq 20 max number of requests by one service thread
req 5081 total # of requests (HTTP, HTTPS, success, failure etc)
avg 1107 bytes average size of requests
rmx 59408 bytes largest size of request(s)
tav 57 ms average processing time (per request)
tmx 9553 ms longest processing time (per request)
slh 1355 # of accepted HTTPS requests
slm 2 # of rejected HTTPS requests (missing certificate)
slc 1625 # of dropped HTTPS requests (client disconnect without sending any request)
slu 1854 # of dropped HTTPS requests (other TLS handshake errors)
sct 150 cert cache: # of certs in cache
sch 4128 cert cache: # of reuses of cached certs
scm 46 cert cache: # of misses to find a cert in cache
scp 8 cert cache: # of purges to give room for a new cert
sst 10 sess cache: # of cached TLS sessions (for older non-RFC5077 clients)
ssh 179 sess cache: # of reuses of cached TLS sessions
ssm 361 sess cache: # of misses to find a TLS session in cache
So i'm still not sure what is causing the high slc.
I don't see chromium v65 listed there...I use the brave browser. am I out of luck?
1 Day 10 hours on rc2. Using 12MB of 250MB RAM.
Code:pixelserv-tls 2.1.0-rc.2 (compiled: Mar 20 2018 21:11:49) options: 192.168.2.2 -c 150 -l 2 uts 1d 10:19 process uptime log 2 critical (0) error (1) warning (2) notice (3) info (4) debug (5) kcc 2 number of active service threads kmx 42 maximum number of service threads kvg 1.32 average number of requests per service thread krq 20 max number of requests by one service thread req 5081 total # of requests (HTTP, HTTPS, success, failure etc) avg 1107 bytes average size of requests rmx 59408 bytes largest size of request(s) tav 57 ms average processing time (per request) tmx 9553 ms longest processing time (per request) slh 1355 # of accepted HTTPS requests slm 2 # of rejected HTTPS requests (missing certificate) sle 0 # of rejected HTTPS requests (certificate available but bad) slc 1625 # of dropped HTTPS requests (client disconnect without sending any request) slu 1854 # of dropped HTTPS requests (other TLS handshake errors) sct 150 cert cache: # of certs in cache sch 4128 cert cache: # of reuses of cached certs scm 46 cert cache: # of misses to find a cert in cache scp 8 cert cache: # of purges to give room for a new cert sst 10 sess cache: # of cached TLS sessions (for older non-RFC5077 clients) ssh 179 sess cache: # of reuses of cached TLS sessions ssm 361 sess cache: # of misses to find a TLS session in cache ssp 0 sess cache: # of purges to give room for a new TLS session
@Protik since you're running with log LEVEL 2, what are the most frequently seen reason code for the ~1800 slu?
admin@RT-AC68U-DF28:/tmp/home/root# grep pixelserv-tls /tmp/syslog.log|grep 'ssl error'|grep -c 'reason(1046)'
568
admin@RT-AC68U-DF28:/tmp/home/root# grep pixelserv-tls /tmp/syslog.log|grep 'ssl error'|grep -c 'reason(1048)'
198
admin@RT-AC68U-DF28:/tmp/home/root# grep pixelserv-tls /tmp/syslog.log-1|grep 'ssl error'|grep -c 'reason(1046)'
205
admin@RT-AC68U-DF28:/tmp/home/root# grep pixelserv-tls /tmp/syslog.log-1|grep 'ssl error'|grep -c 'reason(1048)'
54
pixelserv-tls 2.1.0-rc.2 (compiled: Mar 20 2018 21:11:49) options: 192.168.1.2
155915 uts, 1 log, 2 kcc, 43 kmx, 2.87 kvg, 54319 krq, 176754 req, 1505 avg, 51903 rmx, 71 tav, 7056 tmx, 166285 slh, 135 slm, 0 sle, 518 slc, 9127 slu, 100 sct, 10769 sch, 71 scm, 46 scp, 11 sst, 3404 ssh, 11 ssm, 0 ssp, 161023 nfe, 24 gif, 2 ico, 1588 txt, 1 jpg, 18 png, 0 swf, 10 sta, 5 stt, 87 ufe, 76 opt, 1399 pst, 33 hed, 209 rdr, 1 nou, 1 pth, 0 204, 64 bad, 143 tmo, 520 cls, 2289 cly, 0 clt, 0 err
I think it is this: cdn-gl.imrworldwide.comHas anyone enterprising enough enabled logging to see what’s getting requested?
Mar 18 09:25:59 pixelserv-tls[9055]: 192.168.0.104 cdn-gl.imrworldwide.com GET /novms/js/2/ggcmb510.js?xhr=1 HTTP/1.1 secure
lol. I believe SSL Labs update their list of test clients a few times per year. Usually older clients have compatibility issues. Safari 11 and latest FF are not on the list either.
You have a point. I wonder how they could test latest TLSv1.3 that its draft standard gets updated quite frequently. I guess that's why they claimed to test a quite old draft of TLSv1.3 only.
btw, all latest Chrome/FF/Safari work with v2.1 perfectly.
you know how difficult it is to test for every possible platform/permutation/combination - all becomes clear in time.
speaking of time, I'll believe you (more, implicitly) on the "perfectly" when the rc gets removed from the filename and @thelonelycoder lets us know of the upgrade
Mar 22 17:50:44 pixelserv-tls[9138]: client 192.168.2.51 ssl error:14094418:lib(20):func(148):reason(1048)
Mar 22 17:50:47 pixelserv-tls[9138]: client 192.168.2.54 ssl error:14094418:lib(20):func(148):reason(1048)
Thread starter | Title | Forum | Replies | Date |
L | Is Diversion better than NextDNS, PiHole or AdGuard Home? | Asuswrt-Merlin AddOns | 27 |
Welcome To SNBForums
