Please delete
I am from Germany, bought me an AsusWRT Router and install MerlinWRT.
I set my VPN on the router and all is fine. The only thing which is annoying is the VPN-blocking from Netflix. I already read that i can filter what goes through my VPN and what not. But by my understanding I need the IP-Adresses from Netflix Germany. Is there a list of all IP-Adresses from Netflix Germany. By google i found only the ones of Netflix USA and i think they wouldn't help me (or?).
Is there a list of all IP-Adresses from Netflix Germany or a (easy) way to get the IPs?
welcome to the club. VPN doesn't work on netflix anymore
I would try renting a 5$ Linode, and running the OpenVPN server on that Linode. There's a chance Linode's IP range isn't blocked.
Guten Tag @kindum. According to this article
https://www.comparitech.com/blog/vpn-privacy/netflix-vpn-by-country/
There are still some VPN providers that are able to get around NF VPN blocks. May be best to try the money back trial period to make sure it works before subscribing to a long term subscription.
https://www.snbforums.com/threads/policy-rules-or-selective-routing-question.31326/
Maybe try this solution using the domain names listed below the link?? But these are US domain names. Not sure about DE.
https://www.snbforums.com/threads/selective-routing-with-asuswrt-merlin.9311/page-28#post-318141
nflxvideo.net
netflix.com
nflximg.com
nflxext.com
nslookup nflxvideo.net
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 69.53.236.21 nflxext.com.netflix.net
nslookup netflix.com
Server:    127.0.0.1
Address 1: 107.23.64.107 ec2-107-23-64-107.compute-1.amazonaws.com
Address 2: 52.200.239.43 ec2-52-200-239-43.compute-1.amazonaws.com
Address 3: 23.22.75.169 ec2-23-22-75-169.compute-1.amazonaws.com
Address 4: 34.193.67.217 ec2-34-193-67-217.compute-1.amazonaws.com
Address 5: 107.23.146.34 ec2-107-23-146-34.compute-1.amazonaws.com
Address 6: 23.20.242.45 ec2-23-20-242-45.compute-1.amazonaws.com
Address 7: 52.2.218.47 ec2-52-2-218-47.compute-1.amazonaws.com
Address 8: 107.23.245.127 ec2-107-23-245-127.compute-1.amazonaws.com
nslookup nflximg.com
Server:    127.0.0.1
Address 1: 207.45.72.215
nslookup nflxext.com
Server:    127.0.0.1
admin@RT-AC88U-5248:/tmp/home/root#
@kindum, have you had any luck?
I recently used dnsmasq.log to identify domain names for a certain streaming channel and modified an existing program to route it to a second vpn client connection. You can try turning off you vpn, then monitor dnsmasg.log traffic as you start up Netflix to see what domains it is referencing. Then use the same program I did to route it to the WAN instead of VPN tunnel. You need to have jffs partition enables, SSH enabled, have an SSH client and know some basic Linux to do this.
