A patch panel OR Keystone plugs is a simple way to get a female connector on the wires. Then use pre-made patch cables to connect to the switch.
As opposed to trying to crimp the RJ45s & getting all 8 wires in the correct location to support gigabit speeds is like putting a diaper on a squirming infant while your half a wake. If not done perfectly you end up with 10 or 100 mbit.
Thought I read early on a light or switch was nearby. It would be easy to splice in a line, add a plug & voila power nearby.
If a switch nearby:
http://m.lowes.com/pd/Cooper-Wiring-Devices-15-Amp-White-Combination-Light-Switch/3411814
As for the line marked feed that is most likely your incoming landline. If you have landline service hookup a phone to it and see if you have dial tone.
Probably should have said this earlier - for kicks run a ethernet from your router's switch port to a wall jack. Then hook up a laptop or some other device in another room on a wall jack. I would be surprised if you had connectivity but you never know.
Assuming the feed line is for landline service it most likely runs to your box on the side of the house.
If a switch nearby:
