Thanks for posting Tim. We'd be happy to provide a device for review. If anybody has any questions about it before, let us know.
Neat product - any chances of using a backend to collect reports?
There are 3 different main types of cable testers;technically most of this can be done directly through android phones if you use an adapter, its a lot cheaper and the only thing that cant be done is POE testing. Since android devices can have usb3 ports (my tablet has usb3), by using an adapter you can test gigabit ethernet cheaply. The only issue however are drivers.
For those doing cable installations however, its a much more modern alternative than the old cable testers. Can this be used to properly test CAT specification?
i guess for someone like me who already has tools and can make electronic circuits i just dont see the point. I have my own decent oscilloscope and i can make signal generators as well (premade ones cost loads).
My real complaint was mainly the price, its still cheaper than a decent. not economy oscilloscope and you dont need the expertise to interpret the results i guess.
I just saw the price again and it seems reasonable, i forgot it was below $200. For below $200 i think its good with the software involved. The price is pretty much at the edge of what i consider reasonable. in the UK/EU however it is priced a lot more because of tax. Usually test equipment is priced very high.I could do the same - but it'd be more involved with regards to time/effort, and money to build a board to do this (along with validating that the design works)
I like that it's already done - and the price is very reasonable for what one would get capability wise...
Check directly with the maker.Has there been any update on the VLAN issue - this is a big one for me.
There is post about this where they indicate it will be fixed in the latest firmware version. That post was January 29th. There is firmware that was released on 2017-Mar-10, after the review was posted on 2017-Feb-27. The change log there doesn't indicate that it was fixed.Has there been any update on the VLAN issue - this is a big one for me.
Thread starter | Title | Forum | Replies | Date |
C | So I'm looking at one of these - Intel X550-AT2 Based Ethernet Network Interface Card, 10GBase-T Dual-Port, PCIe 3.0 x 4, Compare to Intel X550-T2 | Switches, NICs and cabling | 3 |
Welcome To SNBForums
