Hi there,
Just got a second RT-AC87R that I have configured as a wireless bridge, using 5GHZ radio and "WDS" feature in the wireless settings tab. I will eventually run a hard line between the two routers, but for now, I thought I'd try the wireless "bridge" connection.
I first updated the firmware to Merlin's 378.54_2. Then, set up the wireless bridge stuff. It actually works pretty well! Only issue I'm having is that I get the following two warnings on the Administration/System tab:
* Reminder: The System time zone is different from your locale setting.
* Reminder: The system time has not been synchronized with an NTP server.
I'm in the US and bought the router from my local Best Buy, so I'm assuming it is configured for the US FCC regulations and consequently my "locale" should be set properly. I set the time zone to GMT-8 (Pacific).
EDIT: Also, what's interesting is if I change the time zone to GMT-7 (Mountain), the
"* Reminder: The System time zone is different from your locale setting" goes away, but the not sync'd reminder stays.
The router's timestamps say Dec 31, 2014 with the clock counting time upwards. It doesn't seem to want to update or sync. The router has been up for ~4 hours now without updating its time. I have tried nist.time.gov (same one Windows 7 uses) as well, but this doesn't seem to cause an update either.
I do plan to update to the next version of firmware that includes the new radio drivers. I've had success with 54_2, so I'm sticking with that for now.
I did some searching and didn't come up with anything like this issue. Any ideas? Thanks in advance!
-Todd
-Todd
