Port 443 - Smart Access
akashi
I have the RT-N66U running 3.0.0.4.376.48_3
I have enabled both 'Cloud Disk' and 'Smart Access' and was able to view the contents of my USB on my Android phone via WAN.
It has suddenly stopped working, I have rebooted the router many times. I also found when I check the ports, both 443 and 8082 are found closed despite having the options enabled.
I installed Lighttpd on entware today but have it running on port 81. This is the only changed I made.
Thanks in advance.
In case anyone else has this problem, I did the following to fix the issue:
1. Disable both 'Cloud Disk' and 'Smart Access' and reboot the router.
2. Re-enable both 'Cloud Disk' and 'Smart Access' and it works.
Update 2: Whilst the above worked, my web server (Lighttpd) stopped working. When I restarted Lighttpd, my 'Smart Access' became unreachable. This is definitely linked as I removed Lighttpd and 'Smart Access' worked again.
