VPN Server on port 53/443?
Yes, but if the client is in restrictive environment this is the only possible solution. The port scanners just flood the log file.
One way to mitigate that is to use the newer tls-auth feature, which I believe allows openvpn to drop invalid connections earlier, and avoiding the log entries. I have never looked into it however, so I don`t know what it`s involved in using it.
+1 vote for TCP/993 (TLS Email port)
Although equally as susceptible to scanning I see far less probing of 993 vs 443 (avg 32 hits/day vs 100+ on 443)
I am using the tls-crypt directive, which is the next level to tls-auth. It does not reduce the noise in log file but stops the scanners at earlier stage.
Thanks for your feedback.
Uh good input! I believe I was able to send e-mails while connected to the hotels WLAN so this might be a good idea.
I am also still looking for a way to make syncthing work in such scenarios.
So I could try using OpenVPN on TCP 443 and Syncthing on TCP 993.
A lot of knocking on the door is expected. Did someone managed to enter though?
I don't know if/how it can be done in Asuswrt-Merlin. Ban for 1h is usually enough to discourage more attempts.
Yes this is exactly what I was thinking and how my webserver is battling spam and attacks... a simple tool to block/ban IPs based on some rules (e.g. getting spammed on a port).
This would be a really really neat feature in Asus WRT Merlin @RMerlin :)
Its available through Entware although YMMV installing on an embedded device, personally I run it separately on a much more powerful Linux machine acting as a proxy
