Good day folks. A week or so ago, I started noticing some errors on my AX88U, with Merlin FW 384.18, and now same issues with the .19 beta. I've taken an excerpt from the system log and it appears to stem around something with the USB EXT4 formatted drive I'm using. I wanted to share what I'm seeing and get some thoughts from folks. Any assistance would be great. I have a spare drive I can reformat/use pretty easily, but before I go doing that, thought I'd ask! I've attached my system log, but added an excerpt of the start of it below .. Thanks in advance!
Aug 4 08:31:51 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
Aug 4 08:31:51 kernel: EXT4-fs warning (device sdc1): ext4_end_bio:332: I/O error -5 writing to inode 30933416 (offset 0 size 0 starting block 14451)
Aug 4 08:31:51 kernel: Buffer I/O error on device sdc1, logical block 14450
Aug 4 08:31:51 kernel: JBD2: Detected IO errors while flushing file data on sdc1-8
Aug 4 08:31:51 kernel: Aborting journal on device sdc1-8.
Aug 4 08:31:51 kernel: JBD2: Error -5 detected when updating journal superblock for sdc1-8.
Aug 4 08:31:51 kernel: EXT4-fs error (device sdc1): ext4_find_entry:1461: inode #30932993: comm hotplug: reading directory lblock 0
Aug 4 08:31:51 kernel: EXT4-fs error (device sdc1): ext4_find_entry:1461: inode #30932993: comm find: reading directory lblock 0
Aug 4 08:31:51 kernel: EXT4-fs error (device sdc1): ext4_journal_check_start:56: Detected aborted journal
Aug 4 08:31:51 kernel: EXT4-fs (sdc1): Remounting filesystem read-only
Aug 4 08:31:51 kernel: ------------[ cut here ]------------
