PPPoE with russian ISP - wrong IP used as default GW.
Sergey
Hi All.
I'm using 380.65 on RT-AC87U.
I've set up PPPoE connection to my ISP. Essentially everything is set up to "auto" except login and password. The problem is that by default P-t-P (remote) address of ppp0 is used as GW for default route, and it doesn't work. I manually changed default GW in routing table to inet (local) address of ppp0, and then everyting was OK.
Could you say whether there is an option in GUI to use local address of ppp0 interface as default GW?
Thanks,
Sergey.
