Prevent ransomware attack
leon
Hello,
From This MSN new https://www.msn.com/en-us/news/tech...dinated-ransomware-attack-e2-80-99/ar-AAH1Wgt
In addition, the Texas DIR is also recommending companies and organizations that they block inbound network traffic from Tor Exit Nodes and outbound network traffic to Pastebin.
May I have some guide on how to block inbound network traffic from Tor Exit Nodes and outbound network traffic to Pastebin using Merlin? The list of TOR exit nodes is dynamic and changing...
Also, it would be good to block access to and from some countries that I have no reason to visit.
Thanks a million!
You can start by installing a firewall script and other blocking tools. Start by inserting a USB stick into your router. Enable JFFS custom scripts and open a SSH connection to your router and install AMTM https://www.snbforums.com/threads/amtm-the-snbforum-asuswrt-merlin-terminal-menu.42415
Once installed run the 'format disk' option, after that's done you can start by installing Skynet which is a firewall extensions that lets you block countries and other unwanted connections https://www.snbforums.com/threads/release-skynet-router-firewall-security-enhancements.16798
Also check out the other scripts like Diversion for blocking unwanted ads. https://www.snbforums.com/threads/diversion-the-router-ad-blocker.48538
