Hi everyone,
I don't know when I'll be able to wrap up an actual release (probably won't until some time in December), so I decided for the time being to upload test builds on Mediafire.
https://www.mediafire.com/folder/bj94sbhrh7e49//Test Builds
While I won't be answering most of the reports posted in the thread, I will be reading every one of them. I'm mostly interested in reading feedback about the new DNSSec support, what might have been fixed (or broken) in Asus's 378_858 code.
A factory default reset is not required if coming from 378.56_2. If you run into any odd issue, then do go ahead and proceed with a factory default reset, in case you might be carrying on some old issues.
Note that these builds have received NO extended testing so far, aside from the RT-AC88U build. Also, the changelog isn't complete yet, you might need to check the Github commit for the details of what was changed (those builds were generated on November 23rd):
https://github.com/RMerl/asuswrt-merlin/commits/master
Thanks.
Thanks.
