Authority
We'll need to know what router you are referring to, as the results will vary for each model.
Hate to waste your time asking... the T-Mobile model. RT-AC68U. I forwarded you the emails from T-Mobile.
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
Thanks, looking, I see I do have error messages when the nasapps are restarted. The two VPN restart tasks and the firewall start tasks are "skipped". It looks like this happens if I have NFS export enabled, and that is throwing an error message too. If I turn this off, the VPN servers start on a reboot.That's right - the option was removed when I merged Asus's UI in. Just setting it to "On" is all it takes.
You can check your System Log for any error message. It does start automatically at boot time for me.
No, none of the MIPS CPU models support it, and won't support it in the future either. This feature is enabled in ARM CPU models only as it demands higher CPU processing power.Apologies if I missed something said earlier about this, but does the RT-N66U support the new adaptive QoS? Because on alpha_4 the option is still not present, even after a factory reset. Was really looking forward to trying it.
Otherwise, it's been fine for me for the last few days. Wired and 2.4 wireless is working.
I use an AC66U in bridge mode with an AC87U. No problems after Merlin fixed the previous bug. Be sure to download the latest 380 version as I also had problems with the first revisions.Got the AC 66 OUT of loop , anyone else using the AC 66 as media bridge with 380. alpha ? I cannot get it to work , as soon as it uploads it goes to router setup page then goes blank , lights go crazy for a few minutes then the asus recovery page comes up and it takes a few times to work , have to revert to 378 56.2 and all is well .
Is there a trick to using this FW I'm not clued into ?
Thanks .
Thanks it was latest Alpha 4 -5 ghe whatever 18th Dec , maybe something wrong with my ac 66 .I use an AC66U in bridge mode with an AC87U. No problems after Merlin fixed the previous bug. Be sure to download the latest 380 version as I also had problems with the first revisions.
Welcome To SNBForums
