The initial plan was for the next release to be based on 3.0.0.4.382, however it seems that 382 is taking longer than expected, so there will be one more build in the 380 series.
Early 380.63 test builds are available on Mediafire. These are pre-beta work-in-progress, and still a lot can change before the beta/final stage.
Those builds are released as-is, with no support for them. I might occasionally refresh them as development progress.
https://www.mediafire.com/folder/bj94sbhrh7e49/Test_Builds
24-Oct-2016: Refreshed builds.
7b46daf kernel: Fixed bad merge for RT-AC3200 kernel
c90170a webui: Added contextual help for NAT passthrough settings
fa53022 Updated documentation
f9aa712 kernel-mips: Patch the 2.6.22.19 kernel against CVE-2016-5195
7e18948 tor: update to 0.2.8.9 (contains security fixes; closes #1067)
3c81765 Updated documentation
bef8fab webui: Created contextual help popups for various Merlin-specific settings
5171f34 webui: remove extra space between "Manufacturer" and ":" to match the other fields on the MAC popups
fafbbb4 webui: Implement our own help array for openHint() so we won't collide with Asus's, and implement a first entry for the IPv6 firewall
b8e8d67 firewall: support fixed interface ID (EUI64) ipv6 destination addresses (based on john9527's patch)
cdefe67 helper: added pc-delete()
821c324 vpn: Made policy rules start at 10000 instead of 1000
16fcf51 webui: Traffic Manager pages do not reside under QoS, so don't label them as such on bwdpi-enabled models
4636162 webui: Use localized strings for Download/Upload labels on Traffic Monitor charts, and remove extra leading space to scale label
7a95789 kernel-arm: Patched all three 2.6.36 kernels against CVE-2016-5195 (Closes #1066)
343d6f9 ipset_arm: some build systems try to link against the wrong library, ensure we do link against our built libmnl.so (closes #1063)
f022993 dropbear: disable MD5 support, for security reasons
74eeda2 rc: re-create passwd/shadow/group after the JFFS2 partition is mounted, in case we have custom configs stored there (fixes #1061)
