[Test build] Asuswrt-Merlin 380.65 alpha builds
I did some further checks with busybox commands and this is what it puts out.
admin@RT-AC87U-A818:/bin# busybox
busybox: applet not found
admin@RT-AC87U-A818:/bin# sh busybox
busybox: line 1: syntax error: unexpected word (expecting ")")
admin@RT-AC87U-A818:/bin# ./busybox
From Ubuntu, shouldn't we be seeing a working busybox like this output?
Exactly, that's the output you get in the non-test releases and will surely be so in the next test release.
I just noticed if I remove a guest the ssid and password from guest corrupts that bands ssid and password in the gui it doesnt apply the settings and it isnt a browser cache issue. ALPHA 4 RT AC5300
There is a problem during reboot if one of wireless band or both are disabled. It takes about 3-4 minutes in this case. On my RT-AC66U router I see that it reboot all interfaces about 4 or 5 times. And only after this long booting the GUI and interfaces are available.
If all wireless band are enabled than reboot takes about 40 seconds.
I get a broken wan connection and long boot if one of the wireless bands is disabled and long boots as well regardless it doesn't work unless all bands are enabled. ALPHA 4 RT AC5300
for some reason i cant upgrade my ac3200 from alpha2 to alpha4, always ending with upgrade unsuccessful. i tried ie, ffox, chrome, three different machines, two different tablets, but no luck...
is there somewhere a log about upgrade so i can see there why it is crashing ?
Same happens with RT-AC87U FW, something went wrong on those files...
Have you both reboot your router before flashing?
I've done better, I flashed it via TFTP and Recovery Mode, no go, flashing old versions all of them work fine, like I said before something wrong with that file, and flashing it via WEBUI it will show the message:
To comply with regulatory amendments, we have modified firmware verification rule to... bla bla.
From 380.64 to 380.65 Alpha4 wish definitely shouldn't happen, didn't lost more time with it since i only wanted to make a quick test on latest FW code, nothing else, 380.65 Alpha 3 has done the job.
I have this error showing up using assarbad script for 380.65_beta1
checking for arm-linux-ar... arm-brcm-linux-uclibcgnueabi-ar
configure: error: We are cross compiling but could not find a properly named toolchain. Do you have your cross-compiling toolchain in PATH? (You can --disable-tool-name-check to ignore this.)
Makefile:1696: recipe for target 'config.status' failed
make[4]: *** [config.status] Error 1
make[4]: Leaving directory '/home/roddy/asuswrt-merlin/release/src/router/tor'
Makefile:2685: recipe for target 'tor' failed
make[3]: *** [tor] Error 2
make[3]: Leaving directory '/home/roddy/asuswrt-merlin/release/src/router'
Makefile:198: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/roddy/asuswrt-merlin/release/src-rt-6.x.4708'
Makefile:2578: recipe for target 'bin' failed
make[1]: *** [bin] Error 2
make[1]: Leaving directory '/home/roddy/asuswrt-merlin/release/src-rt-6.x.4708'
Makefile:2648: recipe for target 'rt-ac87u' failed
make: *** [rt-ac87u] Error 2
make: Leaving directory '/home/roddy/asuswrt-merlin/release/src-rt-6.x.4708'
You need to add "--disable-tool-name-check" to new Tor 0.2.9.8 version.
Not Tor file but ../router/Makefile ( tor/Makefile: )
Jeez...
This file: ../router/Makefile
This segment:
tor/Makefile:
(cd tor ; $(CONFIGURE) --enable-static-libevent --with-libevent-dir=$(STAGEDIR)/usr \
--with-openssl-dir=$(TOP)/openssl \
--with-zlib-dir=$(TOP)/zlib \
--disable-asciidoc --disable-unittests --disable-tool-name-check)
Jeez...
This segment:
tor/Makefile:
It's already there. Hmmmm.... Doing another compilation. See if it gives out the same error.
It's an old bug in Asus's code that I fixed at some point, but the fix got lost with a GPL update.
It seems that we need to add a link/reference somewhere for /home/roddy/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi-ar
Not sure if is 380.65 issue, but after a few days the QoS Statistics are reset!
Is anyone else having same behaviour?
