Zerpersande
I have the new Asus AX3000 installed. Everything seems to be working. It is still feeding the AC85U and it is accessible.When you log into the Asus (the one connected to their device) you should be able to see the "WAN IP" right on the main page. If it starts with 192, 172, or 10 it is a private IP. If it starts with 100 - that is Carrier NAT and a whole other ballgame but still considered "public".
You were right about the new IP address. But the WAN address has now changed to 117. Comments there?
Just got a new Asus AX3000. The AC3200 is now going to be the secondary. The new router’s IP is 182.168.50.1. Should I set the AC3200 to 192.168.51.1?Because your RT-AC85U is/was an Access Point. Use 192.168.2.1 if/when you switch it to Router.
We’re not in an apartment but own a house. But houses are still small. Your assessment is correct regarding need vs want though.You don't need 2x or 3x routers, except to play around with some settings and kill some time. Just one router with her computer wired to it and Wi-Fi enabled is all you really need. I have an idea what's the average size apartment in Japan.
