swetoast
Guest
dude i got the flu..
run it manually /jffs/scripts/privacy-filter
if the result is 33 then this it is 33 cant make it go bigger already explained it over and over.
if there are other scripts running then if they are blocking then privacy-filter wont block those that are already blocked.
and yes you can run each step manually its right there in the script how to
