Privacy Filter (Another IPSET Script)
ahh ok sorry didn't realise had to wait, just started trying to ping sites from privacy list straight away. thank you for your help.
for i in `cat $path/privacy-filter.list`; do traceroute $i | head -1 | grep -oE "$regexp" >> $path/privacy_block.pre; done
awk '!/^127\.)|(^10\.)|(^172\.1[6-9]\.)|(^172\.2[0-9]\.)|(^172\.3[0-1]\.)|(^192\.168\.)/'  $path/privacy_block.pre > $path/privacy_block.list
think i made it safe
@tomsk mind reviewing ?
test version this is without entware run it and check that it hasnt loaded any local lan ips afterwards with the following command
ipset -L privacy-filter | grep -oE '(^127\.)|(^10\.)|(^172\.1[6-9]\.)|(^172\.2[0-9]\.)|(^172\.3[0-1]\.)|(^192\.168\.)'
that line should return nothing
ipset -L privacy-filter | grep -oE '^127\.)|(^10\.)|(^172\.1[6-9]\.)|(^172\.2[0-9]\.)|(^172\.3[0-1]\.)|(^192\.168\.)'
Is it missing '(' ?
According to ARIN private IP ranges are
  • 10.0.0.0/8 IP addresses: 10.0.0.0 -- 10.255.255.255
  • 172.16.0.0/12 IP addresses: 172.16.0.0 -- 172.31.255.255
  • 192.168.0.0/16 IP addresses: 192.168.0.0 – 192.168.255.255
So with that and the 127 loopback, i think you got them all
Is it missing '(' ?
Nice one !
so future plans here for privacy-filter i plan to support ipv6 pretty soon so that those with ipv6 can also benefit from this script although this can only benefit ipset 6.x users.
so i put it up on my personal gitlab
https://gitlab.com/swe_toast/privacy-filter/blob/master/privacy-filter
this is just for review not for actual usage since im unsure on how it would perform gonna need todo alot of testing.
I gave it quick look over...saw a couple of small mistakes, but looks like it will work ok with those corrected.
You got the link-local IP and the loopback... dunno if you need to include the ULA as i posted just now.... wiki says
Local addresses[edit]
  • ::1/128 — The loopback address is a unicast localhost address. If an application in a host sends packets to this address, the IPv6 stack will loop these packets back on the same virtual interface (corresponding to 127.0.0.1/8 in IPv4).
  • fe80::/10 — Addresses in the link-local prefix are only valid and unique on a single link. Within this prefix only one subnet is allocated (54 zero bits), yielding an effective format of fe80::/64. The least significant 64 bits are usually chosen as the interface hardware address constructed in modified EUI-64 format. A link-local address is required on every IPv6-enabled interface—in other words, applications may rely on the existence of a link-local address even when there is no IPv6 routing. These addresses are comparable to the auto-configuration addresses 169.254.0.0/16 of IPv4.
Unique local addresses[edit]
Main article: Unique local address
  • fc00::/7 — Unique local addresses (ULAs) are intended for local communication. They are routable only within a set of cooperating sites.[22] The block is split into two halves, the upper half (fd00::/8) is used for "probabilistically unique" addresses in which a 40-bit pseudorandom number is used to obtain a /48 allocation. This means that there is only a small chance that two sites that wish to merge or communicate with each other will have conflicting addresses. No allocation method for the lower half of the block (fc00::/8) is currently defined. These addresses are comparable to IPv4 private addresses (10.0.0.0/8, 172.16.0.0/12 and 192.168.0.0/16)
so basically update to fc00:: in the regexp and voila :) the loopback is overrated since the regexp is never gonna match that anyways
Line 76: awk $local_v4 $path/privacy-filter_v6.tmp > $path/privacy-filter_v6.pre; fi
Should Be:awk $local_v6 $path/privacy-filter_v6.tmp > $path/privacy-filter_v6.pre; fi
i see you got the nice -n 2 ipset -N privacy-update_ipv6 $HASH $INET6 already ;)
fixed tnx :D found a bunch of small errors with filenames and endings all fixed now.
ran an initial test and it was good for ipv4
:D
ipset -L privacy-filter_ipv6
Type: hash:ip
Revision: 0
Header: family inet6 hashsize 1024 maxelem 65536
Size in memory: 9080
References: 1
Members:
2400:cb00:2048:1::6810:335d
2606:2800:133:206e:1315:22a5:2006:24fd
2400:cb00:2048:1::6810:345d
2400:cb00:2048:1::6810:355d
2606:2800:234:2294:b59:11e7:560:10db
2a03:2880:f00a:2:face:b00c:0:8c
2a01:111:f30e:1790::f001:dcc1
2604:a880:800:10::99:7001
2400:cb00:2048:1::6810:315d
2a01:111:f303:1791::b01
2a00:1450:400f:808::2006
2400:cb00:2048:1::6810:325d
2a01:111:f330:1790::a01
Hi, I am new to custom firmware on router (just flashed asuswrt-merlin on my rt-ac68). A major reason I do this is because I want to do adblock on my router, so I'm intrigued by this privacy filter script and I have an elementary question.
I've looked into AB-solution and uBlockr, and both scripts seem to support installation of custom adblock lists. Currently I use ublock origin on my laptop, and there I can subscribe to several privacy filter lists. If I add such lists to AB-solution or uBlockr, would I obtain the desired privacy filtering? Put it in another way, what additional/alternative features/functions this privacy filter provides that are not available via AB-solution or uBlockr?
This is a newbie question and not a criticism of your work. MANY THANKS for your help!
