Problem in repeater mode... #!/bin/sh: not found ... works find in AP mode?
Livin
I run two AC68U Routers... one as a repeater.
Both run the identical start scripts but when in Repeater mode it seems it has an issue. Should I be doing something differet?
admin@TM-AC1900-1620:/jffs/scripts# sh services-start
admin@TM-AC1900-1620:/jffs/scripts# /jffs/scripts/occupancy_TM1900.sh: line 1: #!/bin/sh: not found
thx!
thx!
Most likely it was copied to that router in DOS/WIN format instead of Linux format. Open it in vi and look for ^M carriage return characters.
Maybe there is some hidden character in the shebang line?
Open it in "vi" (or whatever editing method you prefer) and remove the shebang line and re-enter it.
Does "/bin/sh" exist? (It should)
Edit: John is quicker than I... :mad:
sed -i 's/\r//g' services-start
Should fix it.
