Problem merging two Lan's through OpenVPN
Doesn anyone have an answer to the following questions?
1. The log says that the firewall-start script is working. Is there a way to test if this is correct?
The log is now just filling up with messages like:
Sep 26 17:42:52 kernel: br0: topology change detected, sending tcn bpdu
Sep 26 17:42:53 kernel: br0: port 1(vlan1) received tcn bpdu
Sep 26 17:00:15 kernel: net_ratelimit: 463 callbacks suppressed
Sep 26 17:00:15 kernel: br0: received packet on vlan1 with own address as source address
2. What do these messages mean?
3. Do I have to do something about it, and what and how?
In two separate threads on this forum I have two extra questions.
1. On the server side the client router shows as connecting two different devices. How to split these. Or is this normal with a TAP connection. Are these two connecting cliënts the real ethernet adapter and the virtual tap adapter?
2. On the server side the cliënt router is jumping between IP adresses, while it should be static. How can I lock it to it's own IP?
