I am expecting some problems with connection to 5 GHz WiFi.
I am using latest firmware with my RT-AC68U with the settings attached.
Now when I try to connect to 5 GHz using my Galaxy S3 it tries to do it for some time and then displays "authorization error".
Rebooting the router helps - but only for some time.
I've tried to disable regional restrictions some time ago using
so possibly this is the reason?
Now I've tried to point control channel manually (as you can see from settings screenshot) - now it looks like working but I need some time to test and confirm.
But anyway - what is the reason of above mentioned problem?
nvram set 0:ccode=#a
nvbram set 1:ccode=#a
nvram set 0:regrev=0
nvram set 1:regrev=0
nvram set wl0_country_code=#a
nvram set wl0_country_rev=0
nvram set wl0_reg_mode=off
nvram set wl1_country_code=#a
nvram set wl1_country_rev=0
nvram set wl1_reg_mode=off
nvram commit
reboot
