SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Problem with Apple WiFi stability
Information, such as I have
@tannebil: Sorry, no. In your case I'd strongly advise power line networking to connect the WAP's, don't use a repeater as they are the least stable (data from others, not this particular network), and data rates tend to be terrible.
@claykin: Yes, the wired interfaces never fail. The failures cover at least three generations of hardware, including the latest shipping as of Feb'12.
@tannebil: No further progress, the owner has had no time to pursue this (but still resetting things by power cycles...).
@Mark Uhde: The overlap areas are using 1/11, so is already similar to a cellular network. All SSIDs and config data (except channel) are identical. Aside from the one repeater, there are no same channel overlaps (unit to unit), there are regions where a client has choices between both stations on one channel and at most one on a different channel.
The experiments separating the channels and/or SSIDs is pending. No idea when we'll get back to it (if ever).
